NSSBDT
Paul_CPaul_C Frets: 7855
Don't let @fretmeister know, but I've got a new bass turning up tomorrow.
httpsd1aeri3ty3iznscloudfrontnetmedia707013281200previewjpg
  • SporkySporky Frets: 28777
    That looks jolly serious.
  • Paul_CPaul_C Frets: 7855
    It's like a guitar, but closer.
  • munckeemunckee Frets: 12441
    Im not a bass expert getting my first yesterday, but I think there are too many strings.
    The headstock looks further away!
    Usually I would agree with you wholeheartedly, but on this occasion it has just the right number.
    You might be right there, I'll keep an eye out for that tomorrow.
  • fretmeisterfretmeister Frets: 24680
    I do like the Ibby SR shape.
    I've had 2 6 strings I think. A Washburn and a Status and I just can't cope with them!
    You had a 6 string Bongo once, ridiculously huge thing !
    How on earth did I forget that!
    Stupidest wide neck ever.
  • FunkfingersFunkfingers Frets: 14592
    Wot? Wider than a Warwick broad neck?  :o
  • stickyfiddlestickyfiddle Frets: 27304
    Are you sure someone hasn't just fretted a harp?
    It arrived safely this morning, but only just, as the box it was in survived intact but the outer box has a couple of big rips in it.
    Other than a loose pot and some glue residue from something (perhaps it had been on the wall with a price card attached) it was pretty much ready to go other than a small action / intonation tweak.
    I've tuned it guitar-style B to B (B E A D F# B instead of B E A D G C) so that it matches up with my guitars and Bass VI - to see if that makes it simpler to pick up and play.
    I will pick up some lighter strings at some point but a set of what I want is going to set me back £45 so there's no rush.
    Side by side with the Bass VI the Squier is (other than the width of the fingerboard) slightly bigger so it's not too much of a wrestle to play.
    The only problem is that it's made my music stand look lopsided, but I'll learn to live with that.
    Off with those strings! The Royal Navy is requisitioning your bass to be an aircraft carrier.
    I did the B-B like a guitar on the ones I had.
    Made lots more sense in my head that way.
