40 minutes later and I've worked out these tuners match* my MIJ Paisley Tele and were replaced about 10 years ago with a matching set. Those wider ferrules were still on that guitar because apparently 2012 Mike didn't think it was important. I have now extracted those ferrules and will put them on the Jag with the old MIJ tuners. And then go an order a proper set of klusons for both guitars because FFS...
*actually a 5+1 mismatched set, but whatever..
Full credit to @lamf68 for the finish!!
Lovely colour, I’m hankering after painting something gold soon too. Just looks so good.
I would definitely say my JM is a bit heavier than my Strat, with the extra body mass (I would reckon the trem & bridge is about the same on both). I'm not sure on this Jag yet but the body felt quite light when bare. Will let you know when it's complete. Off the shelf ones from Fender can certainly be boat-anchors, but they aren't always. My old MIJ was under 9lb and super comfortable.
Body was from Guitarbuild and finished by Rich otherwise known as @lamf68 on here and Guitar Resurrection on facebook. A talented chap and an absolute gent.
I would note a couple of things on the body itself... Rich mentioned the body wasn't quite as ready for finishing as he'd have liked - just a couple of imperfections that wouldn't bother me but might piss off others, so something to be aware of.
More annoying was the bridge ferrule locations. They were just fractionally wider apart (max 0.5mm, maybe less) than needed to fit the mastery properly. That would be no issue if you use a traditional JM or Staytrem that pivots, but it was enough that the Mastery wouldn't quite fit first time. Of course I only realised this after fitting the ferrules, which meant 20 minutes with soldering iron and pliers, then a little bit of careful filing to widen the holes just the tiniest amount. It's fine now and I don't mind scuffed ferrules as I can't see them and it's a relic anyway, but obviously it's annoying. I'm not saying this is even necessarily a GB issue; I'm genuinely not sure how close the tolerances normally would be on these sorts of things. I don't know if anyone else has any experiences to add here?
https://www.facebook.com/rendallsrestorations?fref=ts
Anyway, I'm super happy with it - full credit to you!
Wiring neat enough and worked first time. The short-style toggle fits nicely.
Testing with my standard "tap pickups with a pen" method..
I guess about right with my usual cardboard shims. Aptly taken from a bit of Fender packaging
I have strung it and got the action in roughly the right place. It'll need a chunk of fettling over the next few days but I'll let it settle with string tension first. I reckon string tree and logo will go on at the weekend, and a bit of extra rolling of the fretboard edges is always needed.
I'm generally happy with it so far. It sounds about right, though the primary volume taper is shite. I wired the rhythm circuit to mirror whatever the toggle is set to, so you lose the ability to go from bridge flat out to "woolly neck" but you can still get pretty wooly and more likely if I did use it that would be for a clean vs solo option. And I'm glad I have that toggle as Jag wiring has always been annoying. This seems like a decent quality of life upgrade and I don't care about the strangle switch so will probably leave that slot empty for now.
A couple of ongoing niggles - the pickguard is shite and doesn't quite line up with the control plates. I'll need to get a proper Fender one I think as 2/3 of the plates are OEM so that should fit nicely. I may need to re-drill a couple of mounting holes, so I haven't drilled all of them yet.
The neck is very nice and the 7.25"/vintage fret combo doesn't bother me at all so far. Maybe because this is never going to be a guitar for big bends. It will definitely need a few setup tweaks once the neck has settled but the frets seem smooth and flat and the mastery is fantastic. It's nowhere near ideal yet but is already possibly the best Jag I've played.
It's a noisy bugger so I may need to work out if that's just because I'm in a room with dimmers or something else going on. As I type this I have just realised I didn't attached the bridge ground wire, so that may help matters...
Proper pics when the tarting up process is complete!
I have a medium size to-do list:
- finesse position of guard and control plates. I've checked my orders and they're all USA-spec parts other than the toggle plate, so should fit together better. Not a massive issue but a little odd
- get a better main vol pot as it's bobbins, despite being CTS custom
- fit new tuners (they're in the post!)
- more foam under the bridge pickup - it doesn't want to sit as high as I want it
- shielding? Need to do a bit of google on that. IIRC the old ones came with brass plates in the cavities, so that might be worth trying.
- polish up the neck a little bit - it's too satin at the mo
- string tree
- decal
- truss rod
- final check of action & intonation. They're already not bad but can always be improved
- and an amber switch tip - HUGELY important
EDIT: to add more and give myself a checklist of stuff I can tick off...- a couple of layers of cardboard under the toggle plate to raise that flush with the pickguard
- a couple of layers of cardboard between the top plate and switch to lower that just a tiny bit
- nudge the placement of the rhythm pots as one is scraping just slightly on something
- maybe a bone nut, but we'll see how this one fares over the next few weeks
- tighten the staytrem collet (see below..)
I think that's it. Maybe...
