I'm looking at changing the pickup on my shortscale P bass.
The existing pickup has very high poles and as I like to use the pickup top as a ramp that doesn't really work.
In most basses I stick EMGs in but I'd like to keep this bass passive.
Can anyone recommend a good covered P bass pickup, or at least one with visible poles that are flush with the plastic? I can stick a bit of tape over it if the poles are flush.
Not looking to spend loads, the bass was under £150 so I don't want to put £150 pickup in it!
Any ideas?
The latter is actually curved across its top to serve as ramp.
The basschat guys suggest either an Alegree (flush poles) or a Warman (flat plastic) and they are £20 or under.
However - this is me, so there's a very good chance I'll end up drinking too much over the weekend and order an Aguilar DCB which is more expensive than the bass was! (And some Ultralites while I'm at it).
