Given the different scale lengths for each string, you might even be better having a custom set made by someone like Newtone. If not, you probably just need extra long scale, which limits you to something like these...
https://www.stringsdirect.co.uk/strings-c1/string-sets-c865/bass-guitar-c34#t926:t945:t1023
Unless you can find tension charts for the strings in question on those scale lengths, you're going to have to guess really.
Why is the bottom string thinner than normal?
Even on this fan-fret, it's noticeably lower tension, and flaps around
DR pick a 125 for a B string for all their standard 45 sets.
Unless you buy a custom set or a set of specifically Balanced Tension strings then the tension across the fingerboard starts high with the G and gets lower to the E and B.
Thats just the way string makers have done it for decades.
I’ve never liked DR for B strings irrespective of gauge. I’ve always gone back to D’addario steels for 5 strings. You can see tension charts on the d’addario website if you want to go down that rabbit hole.
But if you are looking at flats then it gets even more complicated. Rotosound Monel flats are very high tension for the same gauge as other strings because the core is different. At the other end the wonderful Thomastik Ti flats are very flexible. Everybody else is in between those two.
Just don’t get hung up about the thickness of the string when deciding. Gauge has nothing to do with it.
Dogal and Galli make some non-metal core bass strings and they are so flexible you could use them as shoelaces even though they are still a 45 gauge set.
Do not buy Rotosound flat B strings though. Awful things. Such a dead sound and not in a Jamerson way either.
Tried the Daddario groundwounds? A 125 on the B there would feel stiffer for sure.
Starts with both pickups and then goes to the bridge.
https://youtu.be/ffRoKksKSD0
Maybe this one should have roundwound for a change, I dunno, not very knowledgeable on basses.
Some reviews say this bass is too dull with flatwounds
this DR set is messed up though, the B is far looser than all the others, even though its scale length is longer
Just different choices.
I could buy a 130 then
Except can't see any above 125 here:
Neon Bass Strings | DR Strings | Official Site
1: more people want normal strings
2: Neons are crap in every way and the coating starts coming off after about a week.
I'm mostly a fan of the dub bass sound, like Bill Laswell, and most Reggae bassists in terms of what I'd want to record myself
Of course I am a big fan of Pino and Tony Levin, but don't expect to ever sound like those guys, I'm essentially a guitarist dabbling with bass
I put tapewounds on my Nanyo Japanese 4 string, which I like.
Fender 9050 4-String Stainless Steel Flatwound Bass Strings - 45-105, I got them for about £12 years ago. I've been surprised to see current bass string prices
Some reviews for my new bass say that tapewounds are too dull for it. I have no experience on which to base opinions for different bass strings. Maybe I should just get normal roundwounds and use the EQ. Are any cheap bass strings worth considering? Am I likely to be trying several types of strings, or is there a vanilla solution that I'm bound to find acceptable?
Pino uses Thomastik Ti flats mostly, but will use pretty much anything else depending on the need for the song. He used EB Cobalt Flatwounds for The Who, and also uses Roto steel rounds. His signature Fender comes with Thomastik flats.
Strings make a massive difference on bass. Far more than on guitar so I’m afraid it’s just trying some to see what you like.
however, people do buy and sell used bass strings because they last. Many varieties come up on Basschat. So you can save a few quid while you are trying.
Bass strings are expensive, but as long as you are not looking for that brand new clank all the time, then they will last for years.
Ive never got less than 5 years out of a set of Thomastik flats.
Those La Bella flats might be the highest tension string in the universe at concert pitch. I bailed out of putting them on a bass when the neck was already moving badly with only 3 strings on!
Ultimately though, Pino has been around for decades and has used everything.
