NAD: Spark MINI
  • bertiebertie Frets: 13569
    Switch625 said:
    Would've got one if I didn't have the Spark 40. Would still like to pick one up in the future maybe second hand.
    well if its not "better" than my THR.................... you never know  :)
  • BarnezyBarnezy Frets: 2184
    Surely PG are working on a full sized amp. What are peoples thoughts if that happened. Would create quite a good ecosystem from practice to gig with interchangeable accessories like the BT foot switch.
    Given the 40 was their first ever HW attempt, they haven’t done too bad and this Mini shows they are improving on HW design.
    A full sized amp with 2x8” full range stereo speakers, so the same tones can be used as on the practice amps.
  • RaymondLinRaymondLin Frets: 11878
    I personally wouldn't be interested in a bigger version of the same thing, with the apps feature etc, i really don't need louder or bigger.  But never say never though...
    this  -  I think the appeal is they've brought something "new"  (or good/better) to the portable/micro/jam/practice amp arena
    Other channels are already well saturated with competitors
    edited May 2022
    Had an early surprise today when I got a notification that it was delivered to work!
    The box it came in was much bigger but the actual amp is tiny.  And yes, first impression is that the default setting everything sounds like it is washed with reverb!
    Came with just a Handle Strap and a USB-C to USB-A cable.
    The back of it has headphones out and Aux in.  The port is at the bottom. It's also only as deep as the flat part pf the Spark 40 at the top.
    For size comparison.
    So much delay and reverb in the default settings!
    Let me know your thoughts when you’ve done the firmware update and made a tone you like.
    Any you make, you can save as the default tone on the device.
    Just played around with it more now.  This this is deceptively loud, both in volume and also perceived size of the sound stage.  I really like it, it interacts with my guitar like a tube amp would, it cleans up well as i expect and my PRS SE in the photo above (which is unpotted) does that squeal on command which i love weirdly.
    edited May 2022
    still now't here
    so I ordered a Worx cordless SDS drill to make up for it  (I already have a load of worx powershare stuff)
    EDIT
    just had a txt  - its arriving (oh and now an email, literally as I type)  on Wednesday (the Spark not the drill   )
    Yay !!!
    I think after so many versions of "practice amp" malarky, this is probably going to be my go to from now on.  It's so small it fits on the palm of my hands.  I can charge it with lots of things in the house unlike the Spark 40 or THR where i have to find their own dedicated PSU.  It also sounds good too.  May be because it's small so in my mind i set the bar low but it really does sound pretty good.
    Makes me think why do I need all the other amps now...
    But for £160...it is quite expensive for something this small, then again, I also paid the same for a Klone pedal...so in that regard this is a bargain.
    @RaymondLin ;  -  your thoughts on the comparison to the THR ?
    I haven't done direct back to back comparison yet, will let you know.
    just "gut feel"  and owner/user based observations is all really :)
    edited May 2022
    bertie said:
    bertie said:
    @RaymondLin ;;;  -  your thoughts on the comparison to the THR ?
    Oh, if you offer them both to me at their RRP.  I would pick the Mini.
    I would say the THR do sounds nicer, i think it's because it has 4 speakers in that one? but the Mini is just easier to use, put away.  The main advantage of the THR is the treble/base knob with the various mods at the top.  Each has their pro/cons but I think the MINI wins it for what the purpose of it is.
    USB-C is a big part of that, can literally power it with the port from my computer or Xbox.
    I would actually rank them in the order of Mini > THR > Spark 40.
    The Mini over the THR for convenience and size
    The THR over the Spark 40 for sound and battery powered convenience
    The Spark 40 is fine after a mod but because it needs the brick, it's rooted to the spot, for a living room thing where i move it around and often in the middle of the room on the coffee table, I want that wireless feature.
    thanks @RaymondLin :)
    oh,  the SDS drill arrived just now - its great  =)
    How does it sound? ;)
    like my wife
    just had an email "partial shipment"
    looks like the "crimson grille"  is delayed
    Yeah, or that might be the one coming on a boat from China.
    txt  -  "your DPD driver will be delivering it between 11:28 and 12:28"
    if he doesnt get washed away before hand  (yep its raining a bit...............................)
    its heeeeeeeeeeeeeeeeeeeeeeeerrrrre
