Flux for soldering..Don't know what to buy..
  • euaneuan Frets: 1508
    Careful boys. You might get a telling off
  • LastMantraLastMantra Frets: 3824
    edited May 2022
    CE1 said:
    Usually the main problem when soldering larger things like pots is getting them hot enough. Sounds like the op might need a more powerful iron?
    Quite possibly, or the shape of the tip. I have a pointy one (very technical I know) for most stuff and a wedge shaped one that works well on pots as the contact area is greater.
    Or even a stubbornly dirty/dry tip. Another good thing about having a separate tin of flux is you can dip the tip of your iron in to clean it.
    I generally use a round tip with a flat face on one side. Never got on with pointy ones.
  • BillDLBillDL Frets: 7349
    That's exactly what I do.  I have a small tin containing some of that copper spiral swarf for twisting the tip in, but in between that I just dip the tip into my tub of old flux to freshen it.  The flux in the tub does get manky though.
