I have a classical guitar (slotted headstock, plastic rollers, open gear tuners) which makes a creaking noise when tuning.
It doesn't make the noise if you detune it and just turn the pegs. It seems to happen more on the D string, but it does happen on all strings. The nut seems fine, and i did lubricate the nut just in case. Humidity is normal.
It seems like it might be the rollers rubbing against the inside of the headstock. I've googled this and it seems like the thing to do is take it apart and put lubricant (graphite?) inside where the roller goes. Has anyone got any tips about this, and what to use as Lubricant?
Really!
This response possibly a little late and therefore unhelpful! In which case apologies.
Phone a classical luthier for definitive answer?? Try Earl Marsh in Boston. Quite near if you're in Norfolk. I know Earl and he really wouldn't mind phone call. Nice chap.
Next time you restring use a toothbrush ( new one ) or eyelash brush and clean the gearing. Don't use WD40.
a light machine oil may help but not too much.
This interests me as I live in Lincolnshire and will need someone to dial in my Dove when it's time
EDIT: a quick Google says he's "permanently closed"
Spoke to Earl Marsh, classical luthier from Boston last night on the 'phone for a catchup and mentioned this. He said usual solution is for classical tuners is graphite powder. He was not totally averse to light oil but he did say it was a bit messy.
