@Catthan
As an ex CDS2 owner, Imho I'd say that you've got the wrong amp IF you think it's not loud enough ! Wow, those Redplates are incredibly loud. Mid range or bass tweaks are usually whats needed with them... And less reliance on the drive channel. What settings did you have ?
I believe that sometimes YOU may not be able to hear yourself, but 'out there' they would. Foldback issues are common with a smaller 1x12.
If you are struggling to be heard over the band, maybe a bigger cab might help. It's penultimatley why my RP went, as its a stunning amp BUT not right for me at that time. Its ok to change your amp, and move on...
try a 2x12 or 4x12 and see how that changes things.
i thought i had the ohmage wrong but was ok...
i had the tweed setting with the left hand vol at 7 ....i had the master at around 8....presence fairly high about 7/8 treble sort of 7/8 as well all the other controls at noon... the tweed channel was a very good crunch sound ..i thought the lead went quieter even with the level at sort of 8 ...you could be right about the mid range maybe i should have backed the lead gain and drive of a bit but thought i would have lost the volume...? i had a 2x12 extension cab as well....i just thought i wouldnt have needed that much volume but we are quite a loud blues /rock band
