Or it might be the materials that it’s made from (notice I didn’t say “wood”).
Or it might be the internal bracing.
Or it might be the bridge and how well it’s affixed to the guitar body.
Or it could be an issue with the neck/body join.
Or it could be all of the above.
You can hide the inadequacies of a cheap-shit electric by upgrading some of the components, and tweaking the FX/amp. That’s not so easy with an acoustic.
This will not be a very helpful suggestion I know, but try very dead strings. (Yes, I know that pretty much the only way to make them dead is to wait a long time, or speed it up a bit by playing them which you may not want to if it sounds bad.)
I once bought a cheap plywood acoustic because it sounded very nice in the shop. I knew it wasn't amazing, but it was nice enough for a cheap guitar to take to open mics and jam sessions. The only problem was that when I replaced the completely dead and almost rusty strings, it sounded shit. It remained sounding shit when I tried a couple of other different sets of strings. It finally sounded less shit when I salvaged a set of dead strings from a repair job and fitted those... but still not as good as originally, possibly because the new dead strings were D'Addarios and not some variety of Chinese fence wire. I gave up and sold it.
The only things that you can really change without major surgery, and that have a significant effect on the sound are:
Strings
Saddle
Nut
If these don't have the desired effect you're onto plums.
also IME, there is a ratio of poor sound to cost and size. ie "cheaper" small bodied guitars are impacted more than cheaper larger bodied guitars
Stones, Guns n Roses & Poison Tunes it’s a cheap functional acoustic . I play mainly electric so it was a real winner . It sounds no worse than the EKO 12 string strung as 6 I had at the end of the 80s
IME too heavy a gauge strings dont always work so well on small bodied guitars - 12s tops
