Also have a Fishman Rare Earth single coil pickup, which has no volume control but a really good sound. I've never had feedback issues but the Baggs is the one that gets the most use. The Fishman was a bit cheaper than the Baggs.
Would happily recommend both.
I recently reacquired my Waterloo WLK (initially sold to a very pleasant fellow forum member then traded back). They'd since fitted a Dimarzio black angel and I've been really impressed with it. Comes in a good few quid cheaper than the M80 too.
https://www.fishman.com/portfolio/rare-earth-magnetic-soundhole-pickup/
Have you played both the LR Baggs M80 & M1A? From looking at the specs the rare earth is in the same price bracket as the M1a.
That looks like the one and it's the only one I've ever used.
Yes - I owned a M1A for a while, and have played the M80. I prefer the Fishman (either version), the sound is cleaner and clearer - the M1A is more midrangy, and more prone to feedback, although still not very.
I do like to run my acoustics through a Mesa Rosetta analogue DI if I’m unsure of the PA or engineer, that way I can pre set the tone before it gets butchered.
https://www.mojotone.com/pickups/acoustic-pickups?page=1
I have an m1a in a box somewhere but I hear more love for the m80, which you already have.
I probably should have bought an old J-160E before they became silly money.
I've had various guitars/pickup system over the years, but always struggled in a band situation with acoustics. I just found personally that using the m80 with an acoustic amp into the pa a)sounds great and b) doesn't get feedback. One less thing to worry about. If I was playing in an acoustic band or backing a singer etc then might be different.
Will check out the monotone although I'm thinking of just putting in a jack socket into the LD10 and then being able to swap the M80 between a couple of guitars) it is a ballache moving the LR baggs between guitars but it's not something I'd do that often.
The soundhole pickup i use for other occasions (most of them) because I know I can get a good usable sound with minimal faff, and less chance of feedback. Which is all i need really.
