Picks and Plectrums
13»
  • MellishMellish Frets: 947
    @bertie - sounds like an Aladdin's Cave mate.
    I'd be tempted up in the loft. There might be a Martin D-45 =)
  • bertiebertie Frets: 13570
    ah did that last year when we had the rooves done  -  found about 20 packs of strings,  some pedals and various leads and bits
  • PALPAL Frets: 542
    I have them all expensive ones jazz picks, mandolin picks, metal picks then I got some Fender heavy shell picks and haven't
     looked back. The other thing I do is not use the point I use the side of the pick. The Fender picks are not expensive and
     more importantly easy to get !
  • I bought a pack of those rubber grips with medium fender picks in them and those grips are very good as you can interchange picks with them. The problem I have is that like @PAL I prefer to use the rounded edge of the pick and they are no good for that. When I use the standard pick edge that leading edge on upstrokes the pick tends to dig into strings 1 and 2 and it sounds horrible. With the rounded edge I play much smoother upstrokes.
  • ICBMICBM Frets: 72600
    I accidentally made a surprising discovery at the last band practice… pick colour matters.
    Really.
    I use 3mm Big Stubby picks for bass - not only genuine Dunlops, I got a bulk pack of cheap ones in various colours - purple, blue, red, green and clear. After a 2-hour practice there’s noticeable wear on the tip, and they wear out completely in about half a dozen. I almost always use a coloured one because they look nice, the clear ones are a bit unloved and until now I hadn’t actually used one - but for some reason I did this time.
    It went through a whole practice with no visible wear on it. It appears that the clear plastic is harder than the coloured - amazingly, if you tap them on a hard surface you can hear a difference, the clear one makes a higher pitch. I’m not sure if it affects the sound that comes out of the amp - bear in mind it’s bass ;) - but I wouldn’t be surprised on a guitar.
  • robertyroberty Frets: 10894
    I thought I'd give some other picks a go. It's good to check every now and then. The Gator Grip 1.14 felt good to play at home so I took one to rehearsal. I lasted about 2 minutes and went back to my 1mm D'addario tortex. I'm never changing again
    edited November 2022
    Brought this back out to mention a possible solution for @bertie.
    When Roger McGuinn was in The Byrds he couldn't keep switching from plectrum to thumb/fingerpick cos the schedule was too tight.
    So what he did was learn to do both with the same equipment: plectrum as normal and then, where the fingerpicks would otherwise go, he shifts it over one, so they go on middle and ring.
    @Mellish ;
    do you mean hold pleccy as normal and use ring and middle for "finger picking"  -  hybrid stylee ?
    or hold the pick between ring & middle finger ?
    Plectrum between thumb and pointer, pick on middle and ring
    In other words, you got it first time :)
    ah so just normal  "hybrid"  but with fingerpicks on, rather than just nails ?
    its pretty much how I play when I do use a pleccy for leccy     but I dont think I could do proper "rag" type stuff like that TBH
    Oh it isn't easy, feels like your hand is more closed.
    Or check out the thumb and picks @Gandalph is offering in Classifieds (Acoustics "Various thumb and fingerpicks") :)
    ta -   Ive pretty much got all those metal ones, somewhere  - tried em, didnt get on.  and I dont like those bumble bee hybrid thingys
    Ive found a couple of coloured EBs lying around Ive shaped and "heat fitted"    -  that should keep me going for a while.
    I keep meaning try some different materials,   but life gets in the way  =)
    Should be OK for now then mate.
    I'm off to walk the dangerous beast. He's a Yorke but in his head... =)
  • GandalphGandalph Frets: 1593
    Quick update here....apart from trying almost everything out there going with finger picks I think the biggest personal victory I've had is transitioning form 3 to 2 fingers. Bloody frustrating trying to retrain my fingers but finally feel like the hours have paid off.
    I can't  speak for all styles of play but it works for blues and ragtime and that scratchy sound I always heard with metal picks has finally gone.
    I've wanted to master metal picks for a long time and I think I'm finally there with the Dunlop brass one's. The National brass picks are pretty good too.
    For some reason I've found brass sounds nicer than nickel and they are a lot easier on the fingers imo.
    Im pretty relaxed in my picking style (sloppy ?  )   and go from 2 to 3 to 2 or even 1 sometimes (and that can be any combination of index/middle/ring) without really thinking about it................. a benefit (if it can be called that) is it kind of changes the dynamic of a choon,  sometimes for the good..........sometimes just "different"
    @bertie, if only I was as dexterous! Haha
    I have found having picks on 2 fingers rather than 3 has helped eradicate that 3rd finger from the equation though.
    Sounds a good idea this as it would eliminate some of the confusion from the picking. Fewer options equal less confusion. This is the problem with buying guitars in general!
