Are 000 Guitars Shorter Scale
  • droflufdrofluf Frets: 3752
    bertie said:
    As I'm not going to be anywhere near a Martin,nor Taylor unfortunately,I was hoping for some kind of industry standard. It seems there isn't really.
    there really isnt one,  potatoes pottaaatos and all that  -   the thing you need to do is take note of the specs (scale/fret join, body sizes) and compare that to something you actually know.
    That’s the great thing about standards, there’s so many to choose from.
  • drofluf said:
    Tannin said:
    In the Martin world, 000 and OM *are* the same, except for scale length. I hadn't heard that 12-fretters break this rule, but this is Martin, so who knows?
    This is incorrect, OM's have a 14 fret neck and 000's have a 12 fret neck and generally a slotted headstock. The scale length on 000's can be either long or short.
    Don’t think that’s right. My 000-15M was a 14 fretter with a solid headstock, the 000-15SM is 12/fret and slotted
    I was referring back to Martins long established standards from the 30's when the OM model was developed with a 14 fret neck. Prior to that, all guitars had a 12 fret neck joint, of course nowadays there are so many models that anything goes.
    It's the same with scale lengths, 00's are generally regarded as having a short scale but I have a 00 with a 26 1/2" scale, it sounds great but it's very unusual.
  • CrankyCranky Frets: 2630
    What’d be nice is a wider set of options for cutaway 12-fret 000/00s.  They all seem to be either classical or very expensive Taylor models.
  • Martin 14 fret 000 are short scale and otherwise similar to OM. 12 fret 000 are long scale, slotted headstock and a wider 1/13/16 neck often with modified V.
  • bertiebertie Frets: 13570
    edited December 2022
    the problem with cutaway on a small body,  it can really affect the tone  as youre removing a larger %age of the sound box
