Low gain Rat alternative
  • The @ThorpyFX ;;Warthog is phenomenally good, does the low gain thing beautifully as well as all the higher gain Rattyness, even as a clean boost it’s great, one of the best, most versatile dirt pedals on the market. I have a stock Rat2 as well, which is always good: never be without a Rat  :)
    This. My Warthog replaced a Rat as it could do the Rat thing plus much more. It covers everything from low gain drive to distortion. Even gets a bit fuzz-like if you set it right. Easily the most versatile drive pedal I've played.
  • I only use the Rat on lower gain, it's just stunning at that.
    I have made a few now and I prefer stock to the Turbo, but both are good.
    I like the Red Llama for low gain as well, although I did mod mine and can't quite remember what I did now
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • robertyroberty Frets: 10893
    I used a rat always on with low gain for years. I am playing heavier stuff now so the distortion is dialled up more. The rat sound for me is about the upper mids at any gain setting. Really slices through in a rude but not unpleasant way
  • ewalewal Frets: 2587
    The low gain Rat thing once more. I haven't been enjoying my guitar the last few evenings - everything sound flat and flabby. I half thought it might be time for new strings, but also was suspecting I didn't have the low gain Rat clone dialled in right. So I started experimenting with HXFX gain effects and stumbled across the Deranged Master model - apparently based on Dallas Rangemaster. Well this does exactly what I want my Rat to do - removed all the flabbyness and added a nice presence with the very little clipping. Maybe a treble booster is what I need? Then I can use the Rat for what it is really best at.
    Ahhhhh.... The gain pedal permutations are endless...
    The Scrambler-EE Walk soundcloud experience
  • Dave_McDave_Mc Frets: 2359
    I'm not that well up on treble boosters, but that's what the two I've tried (both Rangemaster-based) did. They're almost like proto-tubescreamers (maybe more like proto-SD1s).
    They are great into a JTM45. I know someone who played a Rangemaster into a Bluesbreaker for many years and that was a glorious sound
  • GreatapeGreatape Frets: 3580
    Also a low-gain.RAT user. Sometimes stacked with an OD-3 or Timmy for a big, round sound that cuts through.
    I’ve got a Timmy but not a RAT. Do you have the RAT before or after the Timmy?
    TC Electronic Dark Matter
    As low gain Rat substitute?
    edited February 2023
    Before. Middle toggle position, a bit of attenuation of treble and bass, gain below noon.
    Yes. I have it next to Rat on my board, and I'm able to set it to sound 99,9% close to real thing. Basically a less hissy Rat with more options (separate bass and treble controls, voice switch). Also dirt cheap.
  • I know it's already been said but Thorpy Warthog is amazing with the gain low and calibre wound down a little bit
  • impmannimpmann Frets: 12668
    No such thing as a 'wrong' way to use a pedal.
    If it works, it works.
    @Greatape ;Thanks. I might try that, as I've been thinking about buying a Rat or building a clone of one.
  • A lot of the BJFE OD pedals are just differently voiced Rats - the Dyna Red or the Honey Bee for example. Original ones are expensive but you can get cheaper clones of them all.
    I find there is a pleasing quality to the texture of the clipping you get from the Rat circuit, that is shared among all of these pedals.
    There is also a Chinese pedal guy 68 Pedals who makes a pedal called the 'Milk Stout' you can often find for 50 quid or so. It is a rat with three clipping options and a sweep control that allows you to change which frequencies are clipped (I think). I have one and it is great.
  • I remember a video on YouTube where someone demonstrated that you can make a low gain Rat and a low gain Klon (or possibly Klone) sound extremely similar. The takeaway was basically "why spend all that money when you can do the same thing with a Rat?" But equally you could use a Klone for that job if you wanted to.
    The only issue with the low gain Rat option is the hair trigger adjustment of the gain control, otherwise it's perfect.
  • merlinmerlin Frets: 6693
    Coming a shade left-field, I suggest Fredric Effects Accomplished Badger 2.
  • ScreamingDaveScreamingDave Frets: 553
    I’m another one who always uses their Rat low gain.  The EHX Soul Food does a similar job, but not necessarily better.  I nearly bought a Soul Food then realised I may as well just stick with the Rat.  As the OP said, if it ain’t broke ……
    Not really a lot of point looking for an alternative to something you’re happy with anyway.
    I kinda get it though, because it’s easy to feel like you’re not using it to its full potential ….. a bit lime using a Ferrari just to pop to the supermarket once a week  :)
