Studio makeover.
  • Modulus_AmpsModulus_Amps Frets: 2596
    Very nice, is it insulated enough to crank amps without upsetting the neighbours?
  • octatonicoctatonic Frets: 33849
    Yeah, that isn't an issue.
    It wasn't really before though.
  • stonevibestonevibe Frets: 7175
    Looking good and should make mixing a lot easier.
    Update: all but 4 of the ceiling and ceiling/wall corner traps are now in.
    Getting this accurate has taken days.
    The cloud in particular was a bugger.
    We used 6 cleats per pair of traps- the right traps are attached to the left ones with a coupling bar.
    The cloud is solid as a rock.
    Everything is taking ages now.
    But it is coming together slowly.
    Yes, I know the speakers are too wide- this is to make cabling everything easier for now.
  • This project has been completed far quicker than my bathroom in in the middle of remodeling. Amazing. Loving that ceiling. I do hope an array of coloured led lights are hidden around too for that atmospheric effect. That crate on the right looks heavy!
    edited February 2023
    No coloured lights yet- I do have Philips Hue here but they are just different shades of white.
    I'm down to the fiddly stuff now- running audio cables through walls and skirting cavities.
    So far the acoustic isolation between the two rooms is fantastic.
    Update.
    Still running cables.
    Yes, a month later.
    But getting close now.
    I need to figure out what I am doing with monitoring.
    The ATC's are too wide with the Kii's in the correct position.
    Cutting down to one pair of monitors is always an option but I am disinclined to do that.
    The ATC's, being horizontal, are tricky to place if you have any other large monitors in the room.
    I could sell them and go up to SCM50's, which are vertical, but that would be another big pile o money.
    Also maybe a bit too big for the room.
    Still need to think.
    The modular desk is brilliant, it is a new design from Buso Audio who also made the main desk.
    In terms of room sound- it is so much better than before, as you might expect.
  • hollywoodroxhollywoodrox Frets: 4214
    Absolutely Fantabulous thanks for sharing it on here it’s very interesting
  • fastonebazfastonebaz Frets: 4140
    It's absolutely super .  That 2nd pic does make me think of  Dr Who's tardis.  All those buttons....  makes my little reaper plugin shrivel up in shame :lol:
    I'm still holding out for an entry to SOTM one month so we can finally hear what a proper quality mix sounds like.
  • It's absolutely super .  That 2nd pic does make me think of  Dr Who's tardis.  All those buttons....  makes my little reaper plugin shrivel up in shame :lol:
    It seems bigger on the inside!
    Wiz'd.
  • SupportactSupportact Frets: 1004
    This all looks fantastic. If you don't mind me asking, did you make the cloud panels or are they bought? And have you got any tips/warnings about attaching them to the ceiling? I ask because I may have to make or at least install a similar thing later this year, so this thread is making me think.
    They are from GIK- 242's I think.
    So hanging those panels was a right faff.
    They were put up in pairs- you can see in the photo that we used 3 support brackets per pair.
    This is because they are all bolted together using a flat piece of metal as a coupling bracket.
    It took over a full day just to hang those 8 panels, with 3 of us onsite.
    Thanks. Sounds like I'll need some helpers then when the time comes.
    Studio renovation is finally finished.
    The only thing that is changing is I'm adding the BXT bass modules for the Kii Three monitors.
    Pics:
  • IMC1980IMC1980 Frets: 146
    Your studio looks fucking brilliant.
  • SporkySporky Frets: 28753
    That looks like a fantastic, productive space.
  • HabaneroHabanero Frets: 255
    I have no idea what that wall of knobs does, but it definitely looks impressive!
  • grappagreengrappagreen Frets: 1349
    Been watching this with interest... I'm super jealous of your setup and I can appreciate the hard work involved (and cost!).
    The left hand window is a little frustrating but all rooms have their challenges! Notice you don't have a great deal of diffusion going on and lots of broadband absorption. floor finish obviously helps but be interested in what the RT20 looks like across the spectrum.
    Do you have any low end mode issues you've had to target with pressure based treatment (or intend to)?
    Most importantly how does the room feel? What's the imaging like?
    Do you have any REW before/afters?
    I'd love to have a listen :)
    Si
