Mouse Replacement
  • Vintage65Vintage65 Frets: 336
    Most DAWs these days have tablet remote control functions
    I've tried it but found it a bit laggy and uninspiring. Maybe I should give it another go, although I do favour the tactile side of things.
    octatonic said:
    I use Streamdeck with Soundflow for custom macro heaven.
    It is seriously powerful, but takes a bit of time to program.
    Here are two, the first one I made including the icons), the second one came from another community member.
    My one has all my most used Pro Tools commands.
    The second one instantiates some commonly used plugins on the selected tracks in the next available slot.
    I have them (and about 20 other decks) on a Stream Deck and on an iPad and they have been programmed to switch contextually.
    In the next versions of Soundflow & Pro Tools I will be able to put commands on to Avid hardware such as the Avid Dock.
    That said, I still use the mouse a lot.
    There is no getting away from it.
    Very impressive, and something I never knew I needed! You are right about the mouse, and hopefully a trackball and/or pen tablet can take it's place.
  • SporkySporky Frets: 28574
    I switch between mouse and trackball. I find mouse more accurate for fiddly stuff, trackball more convenient for most things.
    There is, to me at least, a big difference between trackball where you work the ball with your thing, and ones where you work the ball with your fingers. I'm hopeless with the former, the latter feel much more natural.
    Maybe also consider a touchscreen? That'd let you interact with controls directly.
  • GoFishGoFish Frets: 1431
    Has anyone used the OLD style Kensington trackballs? I've been curious for a long time and saw they still make em.
    edited April 2023
    I just received a large trackball device and it seems to be quite accurate due to the size of the ball, and I can make micro adjustments in plugins with the large scroll wheel. It also has speed acceleration, so it's easy to zip around the screen. I tried a PC control app on my tablet and it wasn't very accurate when it came to fine-tuning parameters.
    edited April 2023
    I got one of these as I prefer wired.
    https://m.media-amazon.com/images/I/71M49-nEesL._AC_SY450_.jpg
    edited April 2023
    XL version currently on sale at Curry's @ £184.00
     https://www.currys.co.uk/products/elgato-stream-deck-xl-10194985.html
  • BodBod Frets: 1316
    Sporky said:
    There is, to me at least, a big difference between trackball where you work the ball with your thing...
    Mrs Sporky's a very lucky lady.
    Yes, it's not many husbands who confuse their thumb and their thing on the Internet. Probbly.
  • fretmeisterfretmeister Frets: 24502
    BlueStrat said:
    Logitech trackball like this, hate using a normal mouse
    Deal: Logitech ERGO M575 Wireless Trackball Mouse - Easy thumb control, precision and smooth tracking, ergonomic comfort design, for Windows, PC and Mac with Bluetooth and USB capabilities - Grey https://amzn.eu/d/4XoWA09
    I've used these for years. I much prefer them to a mouse for everything - including gaming.
  • octatonicoctatonic Frets: 33820
    That is the one I have.
    edited April 2023
    I just spotted the Stream Deck foot pedal which I could use for loads of different things.
    I just spotted the Streamdeck foot pedal which I could use for loads of different things.
    Yes, that is good.
    edited April 2023
    Yes, that is good.
    Have you got a foot pedal? Any idea on longevity? I found some interesting videos on the Stream Deck XL and I think I will have to get one.
    Vintage65 said:
    Yes, that is good.
    Have you got a foot pedal? Any idea on longevity? I found some interesting videos on the Streamdeck XL and I think I will have to get one.
    Yes, I do.
    It isn't as hardy as the other devices but as long as you don't stamp on it then it will be fine.
    Another thing I do quite a bit with is home automation. I've got a few Philips Hue Smart Buttons in the studio, which get used for turning on/off lights but also studio monitors, the modular synthesiser system and any equipment that has inaccessible power switches (at back of the rack) or, in the case of an SSL G Bus compressor, no power switch at all.
  • octatonic said:
    Vintage65 said:
    Yes, that is good.
    Yes, I do.
    Chapeau, this is brilliant. So many nuggets of gold, I don’t know how I got myself dressed in the mornings before I found your contributions on here. Forum mvp.
    I was looking at the streamdecks a couple of months ago and they look amazing. How are they to programme? Like most similar things (midi anyone?) I’d guess it’s more a question of figuring out how you want to programme it than actually implementing that.
    Combo of plugins and keystrokes. The software is pretty straightforward.
    octatonic said:
    Vintage65 said:
    Yes, that is good.
    Yes, I do.
    Thank you.
    It is pretty straight forward if you use Streamdeck's application.
    I don't.
    I use Soundflow.
    It is far, far more powerful but a bit more complicated to use.
    It does many things you simply cannot do any other way.
  • equalsqlequalsql Frets: 6142
    I loved my old Kensington trackball pro. The scroll ring finally gave out on it after many years use. I stripped it down to try and repair/clean it, but could not get it working. I replaced it with their Slimblade version that I got on a good deal through Amazon.
    It's a good trackball but the buttons are not as good as the pro and I preferred the scroll wheel as opposed to scrolling using the ball on the Slimblade.
    I definitely recommend the pro version.
    octatonic said:
    Yes, I do.
    Thanks for the info. Can the pedal do momentary and latching? I can't seem to find this info anywhere.
