Hi...My Nord communicates with my TC Helicon vocoder via midi. Works just fine and as it should.
I'm now using the Nord as a controller for my Korg Opsix. Again, works as expected.
But now I want to use all 3, Nord => Opsix => TC Helicon
Opsix has only MIDI in and out, and the chain above isn't working. The Vocoder isn't harmonising with the Nord chords I play.
All the Receive and Transport are on on the Opsix. I'm assuming info needed by the TC H is not getting through the Opsix.
What do I need? Do I need some sort of MIDI patchbay type thing? Or am I missing something obvious in the set-up?
I can’t track down the tc helicon model you quote but suspect it just has midi in ?
https://www.ebay.co.uk/itm/266247888262?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=r-YfxATSRsu&sssrc=2349624&ssuid=NZNt7zRaSxm&var=&widget_ver=artemis&media=COPY
That's really helpful. Will that Kenton thru allow me to hook up 4 eg synths and control all the same?
Yup thats what I need.
Dont supposé you know, do they all need power? Or, another way, is the one that doesnt?
https://www.ebay.co.uk/itm/185825500486?hash=item2b44101d46:g:OLcAAOSwTo9j~NqP&amdata=enc%3AAQAIAAAA4ADGgsU9S%2FAOfKa2HBhR5f9ymSehtn8YNU5VMFZ8F%2Bm8OyFWcE1LBjfhPPlGJ21jpKXSWr21Dy2HySU8n6JcLMmvSWP4vtoKzR3%2BE6xIMMWgxROcCkOSDStaXftZn6TAzN%2BbK%2Fcis%2BRvOLn9sS4YxzTRIsVVuAR8ZnGwnospqVg%2FvuTMRr9ntJfOuST%2FNBIHHAICXutd9GmoDUzn3yrwkGNY6VRMxZ4A6cijDpxEQI%2FzQ3nbkyDhej4gfRnxoTiFKiwKVAXLAIFUkp0lnd4d%2B06k7SIphFG%2FO3FIrESRRwKp%7Ctkp%3ABk9SR7bvkMmBYg
This appears to be unpowered...Do you know if I would want the 'switched' or 'unswitched' version? Nord out, via thru to Opsix, TC H and Audiothingies MM2
https://www.ebay.co.uk/itm/134133259343?hash=item1f3af71c4f:g:nR0AAOSwyE5iHTwG&amdata=enc%3AAQAIAAAA4NAQLCafA6t6apgNdOS6HlMGJq58v6DdesNrQ33Ks66sXLjGtZGkwnOPCI7%2BBjq1h2PMF97mRSAfn0aToVHdAPTMuWh6d0WOvwfCbPsny8NoBAmic2jSUQ2vmx%2FDRhgdKIcZGsqJmk0PGwy%2F9LzEhBR2koyGWTNMMwU4L0RpOqz2B3mI6gLt%2FmQeKJRm6WPmUpCbdGBxKK2CBl8G%2BdUoEYFu1WQxBMxCtm4nWP7vqm3sPK%2FvRPSC6IbJDMXYtOS%2Be84GA%2BC2Uw9F0SbrbOlX3S1l4a3m8dkHGXyeQxw2YSWK%7Ctkp%3ABk9SR7jvkMmBYg
The Audiothingies Micromonsta 2 is a tiny and rather cool little synth
