Ian
The odd thing is that this bridge pin has been in the bridge since I collected the guitar a couola years ago.
I would not use electrician’s tape - it will leave a sticky mess in the hole which will be very difficult to clean out. If you must use tape, paper masking tape is much better.
Ian
[EDIT] For clarification in case some nugget glues the bridge pin into the hole. I am referring to smearing glue on the pin after removing it, allowing the glue to cure, and then pushing it in again. The idea is that the tiny bit of extra girth created by the glue will make it fit more tightly in the hole.
