Hi all,
another newby bass player here… thinking about lightweight but gigable amplification… And I like the idea of a mini head and then getting a couple of bass cabinets as and when I can afford them, to suit different venues/home use.
But one of the issues I am having is fully understanding the power output. From reading some of the previous comments on other posts, I can’t trust a stated power output because its peak power, rather than RMS.
so looking at the cheap and cheerful
TC Electronic BAM 200 Ultra-Compact 200W Bass Head
For example, why isn’t the rms clear? What kind of real power will it provide in gigging terms? (It’s a 4 ohm speaker output)
Has anyone used the above? Or have a similar priced alternative recommendation? Would a combo just be a better solution…
other finger wagging or thumbs up recommendations welcomed
The only way is to suck it and see, or trust the word of others. Sadly I don't have experience of that TC head, so I can't comment. I do have their BH250, and with an efficient cab (a Barefaced 1x12), I've found it loud enough, but the cab is a significant component of that set-up.
the TC 500W stuff is only a little more expensive. Or have a look on Basschat in the classifieds for a used bargain.
For example, the Fender Rumble 200 only achieves 200w when an extension cabinet is added. On its own, it is more like 125w.
I do have experience of tc electronic bass amplification. The rig I use is similar to the RH450/RS210. Its notional 450w is more than I have ever needed but that is kinda the point. The amp is loud enough and never strained.
They should have been honest about it though.
For the OP though - A used Ashdown RM500Evo2 can be found for under £300 if you are patient, and Ashdown's customer service, even for used stuff is amazing.
Always worth keeping an eye out for Thomann gear sales. I got a Tech 21 VT500 for £159 when they were clearing out stock and everyone else still had them at £699!
So I would say, based on that - 250W into an efficient 15" or maybe a 2x10" is enough, but through a small cab you'll probably need more power.
BUT it's a Class D/SMPS amp, and they're not as loud as comparable-power-rated Class AB/linear power supply (transformer based) amps. Why, I'm not 100% sure, but you'll know it's true when you try both types of amp in a band context.
On the other hand Class AB/linears are heavier and bulkier... take your pick.
I am acutely aware that the tc electronic "450" is nowhere near as powerful as my old Marshall DBS7400's 400w RMS.
Modern amplification is a huge trade-off for portability against performance compared to old-school stuff of even far less power rating.
My old 250W Trace Elliot MkV through an old Marshall 1x15" folded-horn cab with a Celestion Sidewinder was astoundingly loud - the 500W Promethean doesn't even come close through two cabs. Although it has to be said that the Trace *head* alone weighed twice what the Promethean *combo* does. And I have no idea what the Marshall cabinet actually weighed, other than "a lot" - and required two people to lift and an estate car to get it anywhere.
I have a BAM200 and like it for a few reasons:
- it is so small, as you can see with my mobile on top of it, it easily fits in my gig bag,
- the headphone socket is great for silent practising at home,
- the XLR out on the back sends a feed to a mixing desk (which is what I use it for mostly) and the desk can boost the signal however the sound engineer wants,
- the 4ohm socket I have not yet used but is there should I go somewhere where there is a bass cabinet,
- I also use it with my ordinary 6-string guitars, this weekend with a Strat and 3 pedals.
Edit: I forgot to add that the article New TC BAM200 micro head is worth reading.
If you’re in a Motörhead tribute band I would look at something else, if you’re in a trio with a moderate drummer you could be ok with a decent cab,
For the money I think they are hard to fault.
Stand that on top of a 1x15 or 1x18 and I'll be happy to gig at larger venues.
but this little home research article suggests air pressure waves being more troublesome than direct floor / cabinet contact for resonance issues with non solid floors. There a handy bit of evidence for using a couple of layers of rubberised draw liner between cab and amp (significant vibration reduction)
https://www.bassgearmag.com/submit-article-bass-amplifier-isolation/
