Today’s lesson learned came in the form of dots. Really small dots.
If you need 10 side dots, for goodness sake order more than 10! They are fiddly little buggers and you will drop some and you will not find them.
Instagram
I’m normally pretty good at that, but they kind of pinged and bounced off a tarp that’s over my bikes. 2mm abalone dots on a dusty garage floor not mixing well!
They are marginally more visible than black pearl, which can totally dissappear
Instagram
First I built a neck carving support out of a bit of leftover timber from my bench build. I wrapped a PVC pipe in sandpaper and used that to sand a concave radius into the top to support the fretboard, then covered it in cork. The cutouts are to enable me to get calibers in at the 1st, 6th and 12th frets to check the depth. I drilled a couple of holes at each end to enable clamping and used another offset with a dowel in to create a riser for the headstock support which can be moved to either end in case I want to rotate the neck. (easier then moving the whole jig around).
Then I made a couple of templates. I printed them off the internet, cut them out and drew round them onto MDF before cutting them out on the bandsaw and then using the spindle sander to finish them off. I then put some water thin CA glue to harden the edges and prevent fraying.
You may also notice todays lesson in picture 3... Apparently I drilled my fretboard locating hole too deep Luckily I used a wooden stick to locate it, so now it just looks like a knot or a birthmark! It shall serve as a reminder.
Actually starting to think I might pull this off. Lots still to do and plenty to go wrong, but this almost looks like a thing:
The nut end looks like it's got a similar flat spot that could do with rounding out.
The transitions are always the hardest to perfect and get flowing right.
Instagram
I wasn't sure how far to push it. The template had some lines roughly following that triangle that I assumed was supposed to be flat. Going to have a look at a couple of my guitars too to try and see how their transitions are.
