WezV - Offset DC Jnr build
  • paulnb57paulnb57 Frets: 3073
    Looks great...Id be slarring Tru Oil on that!
  • WezVWezV Frets: 16793
    It's thinned nitro at the moment, so I will carry on with lacquer.
    I have a couple of white filler options to try
    Also, I've just worked out this is my 75th build over the last 21 years!!!
    That's not including the partscasters or refurbs I have done along the way.
    0reaction image LOL 4reaction image Wow! 1reaction image Wisdom
  • SteveFSteveF Frets: 539
    Wow Wez! That's impressive. Special engraving on the truss cover perhaps?
    That's not a bad idea
    Cat hair
    A lot easier than the Internet makes out.  2 coats of balck nitro direct to wood, then I used the white from a wood repair kit... this is already a thin paste.   I rubbed it in and then cleaned it up with isopropyl.
    Oh my! Ive just had a moment, thats fabulous!
    That looks great Wez. Same on the back of the neck?
    Yeah, I did it all over.   Obviously the maple stripe has no grain to fill which creates a fun look on the neck shaft
    Nice  =)
  • davrosdavros Frets: 1353
    Ooh tasty, like an inverse TV Yellow in black and white!
  • Winny_PoohWinny_Pooh Frets: 7802
    Damn!! That looks great
  • Jez6345789Jez6345789 Frets: 1801
    That’s looking real sharp
    edited August 2023
    Very similar.
    It's originally a 60's Epiphone colour called Silver Fox, but more commonly referred to as Doghair these days, since Collings brought it back.   Those old epiphones often look very green these days... I think I will keep the tint light on mine
    The technique is called Ceruse
    edited August 2023
    there are a few small imperfections in the finish.  Nothing fatal, but I thought I would show the fix as there are no 2nd attempts with a finish like this... you can add more filler fi needed, but can't easily take it away
    I did 2 rounds of sanding on this from 120-320g mirka goldflex, wetting the  grain and letting it dry before each session. it was as smooth as anything, but the filler still showed some tiny flaws
    sounds like a hack fix, but everyone need a black sharpie in their tool kit.  Here I used a fine liner to touch up some of the flaws that had been revealed by the filler.
    Before
    after
    before
    after
    Before
    after
    before
    after
    edited August 2023
    edited August 2023
    Looking great, will be even better with the clear coats on. Can see it with a big chromey pickup in the bridge (covered PAF or big filtertron)
    edited August 2023
    I was thinking of sticking with the open humbucker.... or possibly getting it a raw nickel cover... or a metal ring
  • SporkySporky Frets: 28729
    That looks ace.
  • PeteCPeteC Frets: 409
    Fab !   Raw nickel cover would go well with the engraved ali plate - especially as it ages.   Marvellous looking guitar Wez.
