At some point in the bearish future M2 iMac's will hit the market, so wait until then when M1 versions hit the market.
However I'd go with an apple silicon Mac mini, just make sure you specify a minimum of 16GB of memory.
You will find a huge different between the performance of your old core 2 2009 Macbook and a quad core Imac from 2013 onwards. If you go for something like a 2016 quad core with 16Gb ram then I doubt you will run out of power.
A lot of iMacs have been upgraded with SSD's ... and this is a good thing is done correctly but a lot haven't been. When an SSD is fitted in place of the iMacs original drive a sensor is no longer present leading to the SMC unable to read the HD's temperature. So after a while the fans will kick in at full pelt which is noisy and annoying when doing music production. If the upgrade was done correctly then a third party SATA adapter would have been fitted and it won't be an issue.
Any reasonably competent person can upgrade one of these machines themselves and I have written out exactly how to do it and what parts you need in our Community Repair thread on here.
https://www.thefretboard.co.uk/discussion/192351/the-community-repair-thread/p8
You can of course just go with the fitted normal HD / Fusion drive and track to an external drive. It's not essential to have an internal SSD.
Budget wise a used 2016 ish quad core iMac would probably be about £500 ish
Thanks everyone for your advice.
I think an imac is the way for me
Admittedly this is an extreme example as my iMac is a mid-2011 model and you might be fine with a more recent one.
Used 2021 Mac Studio is going to be the best option for most people if you can afford it.
Bags of power and you will get 5+ years out of it.
Mac Mini is always under specced in terms of ports, RAM and drive space.
Once you spec it out properly (32GB, 1TB, faster processor) you might as well buy the Studio.
Buying a new base Mini is almost always a mistake, if not now then in 2 years time when it is out of grunt/space/RAM.
If you just want something to record audio and aren't interested in virtual instruments, video editing or being current then pretty much any Mac from the last 10 years will do it.
You can buy yourself a lot of time by learning how to backup, format and reinstall.
A fresh OS with the data put back is often the best way to get another year or so out of an old machine.
More people should do it.
Anyway what I wanted to ask was why you said your Mac is on the way out..... how can you tell? Can you fight it?
thanks
Those that know me will know that I am the kind of person to keep hold of things until the TRULY need replacing - I'm not the guy who has to have the latest phone, latest computer etc.
My MacBook has served me very well for the almost 15 years I've had it. However, the OS is no longer supported in many regards, so I can;t update certain apps, resulting in sluggish internet browsing, unable to update to later versions of my DAW etc etc.
I've had a SSD fitted (500GB) whuch has kept it in the game, so I'm still happily able to produce music, but the limitations of my machine are very apparent when I use it.
So your Mac was notably slower and unable to accommodate or comply with updates? Did you feel fitting the SSD was helpful? Sounds like a good move..... would you mind telling me roughly how much something like that might cost?
Own a M1 pro 14 inch 16gb/512ssd base model. - Loads more than i need using lots of tracks/plugins etc.
Also M2 Air base model - holds up surprisingly well vs the pro and loads handles everything i do on the pro. With lots more hours use, its battery life remains at 100%, wheras the pro is 85%. Both similar age. So longevity, with no fans, less to go wrong i suspect ill get another 10yrs+ out of mine.
I would deffo go M chip whatever you do. M1 air base 2020 is sweet spot imho as has 2 sticks of SSD meaning very quick disk speeds and 849 brand new today at currys, so second hand values represent good bargains for what you get.
Similarly M2 air or M1 pro 14 inch also very good second hand bargains imho. Both way more than you need imho, the screen on the m1 pro is truly stunning.
With both , a cheap s/h monitor will do the job if you prefer a seperate bigger screen.
