I received this review of the Tweed Bantam I built a few months back for a customer (who also owns a standard Bantam), and being quite pleased with it, I thought I'd give it an air! What's interesting I think is that the preamp is altered to match the Fender 5E3 Deluxe, but barring a couple of small tweaks, the power amp is still the same as the standard Bantam (and Roadstar) being a pair of EL84s, cathode-biased with no NFB, from which you would normally get that range of Voxy-Marshally sounds you'd expect.
"I just wanted to drop you a line and give you an update on the Tweed Bantam you made for me a while back.
In short, it’s bloody excellent.
Now it’s settled in, I honestly don’t think it could be sonically more different from the Bantam. There is a LOT more low end in this amp, and also some serious highs too. The most striking thing about this amp is how much character the sound has.
Where the standard Bantam might be considered polished, even, and fairly balanced sounding across it’s range, the tweed version has definite accentuated frequencies (all in the magical mids) that give it a wonderfully woody character. It’s not as polished sounding as the standard Bantam, but then that’s not the point.
The thing I’m enjoying most about this amp over the standard Bantam is that- although it takes pedals well - it almost seems to tell you *you don’t want that pedal in front of me, just plug straight in*. It’s a rhythm player’s dream in that regard. A delay is about the only thing I run into it.
The clean, crunch, blues and lead sounds are simply massive. Although it is definitely a rhythm guitarists dream, the lead sounds are soooo thick, I honestly can’t describe how fat and satisfying those sounds are. It almost lulls you into thinking it’s a rhythm amp, then it goes *oh by the way, I do these massive lead sounds too - is that OK?* - gotta love the 5E3 preamp circuit!
It’s taken me a bit of time to get the sounds I like together, so I plan on doing some clips for you in due course. I just wanted to let you know that it’s a fine piece of work and I am still very much loving it."
Feedback
That's astonishing.
*drools*
Tweedy style amps are magical sounding, and do take pedals so well. I love the deluxe 5e3 circuit, and the tweed bassman, which is pretty much just big brother I think?
Cool
Yep, same power as the Roadstar. Actually it's about 16-17W clean, going to about 24W fully clipped. Depending on how you measure it of course. Easily giggable.
In fact the Tweed Bassman 5F6 is quite different to the 5E3 Deluxe. It's a far more refined amp, with it's cathode driven tone stack, LTP phase inverter, negative feedback, fixed bias, 6L6s etc. It's a lot smoother, with a more progressive break up, and doesn't have the raw edge of the 5E3.
Maybe something like this then
