Also means you can get an accurate analogue CE-1 as the Waza CE-2 contains the chorus circuit from the CE-1, but not the preamp so it sounds a lot cleaner than a real one.
Ive owned a couple of CE1s, now sold (obvs), and the pre-amp was amazing.
Well.. Christmas is coming up soon..
(and I've just forgotten all about the HX One... ).
Neither does the Echoplex delay / preamp.
Mind you I really miss my old DOD FX10 BiFET Preamp. That did have a tone control that was quite subtle. I used to use that in the loop for solo boosts.
I'm hoping that something similar will come along now that Digitech are back
edit: the knobs are labelled
https://www.pmtonline.co.uk/boss-bp-1w-booster-preamp-pedal
