It's not like I'm saying everyone should use their thumb for everything that they ever could use it, but to say never is just as stupid.
https://edmorgan.info
The classical guitar repertoire contains pieces that have the fretting hand thumb clearly indicated in the score. Giuliani springs to mind (and he is a pretty important figure in CG - as a composer, virtuoso and author of one of the first methods), also some baroque pieces will benefit from an occasional thumb fretted note.
It's much less common in modern repertoire, mainly because the modern classical guitar fretboard is wider than its predecessors, and as a basic default you get beginners to centre their thumb behind the neck opposing the fingers, but that doesn't mean thumb fretting is ruled out because its 'not proper'.
So yeah I'm a classically trained C/D I guess ;-) As someone said earlier, if you play bluesy/folk fingerstyle its pretty essential. Currently working on several Tommy Emmanuel numbers, impossible without thumb fretting if you want to play the same notes he does. John Mayer's stuff springs to mind too, can't play that very well without the thumb. Electric also - eg Hendrix.
Its all about the music and what is the best way to achieve an end.
However, there are some who can get away with it - and get away with it very well indeed.
I've always avoided huge stretches and tortuous chord shapes otherwise. About the most energetic I get is holding down an A chord with my index finger and then playing an A note at the 5th fret on the top E string with my lttle finger. Quite a common chord shape in Piedmont Blues with an easy change to A7.
But generally I agree. If you play a lot and do extreme left hand positions towards the extremes of your limits you WILL get injured imho. What those limits are will vary from player to player.
Full barres are quite 'stretchy' for most people but they're rarely a huge feature of many pieces.
You certainly need it there for some things though, but I've always thought that there should be no rules, merely suggestions.
I can't get my head around the bending strings disadvantage though. I've just tried it on a narrow necked acoustic (43mm nut width) and it just seems a whole lot easier with the thumb firmly on the back of the neck.
The ideal is to be able to quickly move between thumb-behind and thumb-around, depending on what exactly you're playing. In my opinion.
Essential for those Tommy E fingerstyle tunes
My YouTube Channel
