We're a living room band in need of new mics. One of the guys suggested wearable mics - any recommendations for something cheapish?
The theory is it might be less trouble than our current setup of three mic stands in a room full of keyboards, amps and guitars (and old men).
We could just stick with proper mics but one of the guys is rubbish at putting his head in the right place to sing while he plays keyboard so a wearable might fix that. Mics would need to be directional to minimise music spill of the rest of us playing as we record 'live' , multitracking is way too much work for us.
Thanks for any comments!
Also presumably I can get my antique SM57 fixed somewhere? Anyone know a mic repair service?
Have you tried contacting Shure re the 57? TBH it may be well be uneconomic to fix.
I ended up using it for singing as well when my old band played some stages that were so small even the space for another mic stand was a problem!
It worked very well for backings, but I would say that for lead vocals it (and any headset) can be a bit lacking and the mouth to mic distance cannot be changed for dynamics / close effects etc.
Ebay mark7777_1
Kill him. Or at least beat him soundly. A much cheaper solution. Basic mic technique isn't that hard, and if he really won't co-operate, just set the mic up for him so he has no choice. Then kill him. Just in case.
In a band environment you generally want the directional capsule which requires better control of singing volume and is more sensitive to position.
Amazingly DPA sent both types down for us to try out. Amazing quality mics but overkill price wise for the application here I think.
The Sennheiser one that comes with the G3 wireless mic kit is pretty good and can be had for less than a hundred on a good day.
You can fix the 57 yourself, they are very simple and either a wire has come off or capsule is dead so just change the whole capsule .. they are readily available
With regards to your SM 57, it is probably cheaper to get a new one as the cost of the Shure capsule is about 80% of the mic cost
Musical theatre performers are excellent but their needs are not the same as a lairy metal frontman who likes to use the proximity effect to produce overwhelming low end on selected notes. Human volume control cannot duplicate that.
