Generic power supplies can sometimes be noisy when used for audio applications, but you'll need to try yours to see if it is.
The manual also says you can use 9-18v to power the pedal, suggesting that there's some sort of conversion going on inside the pedal to change the supplied voltage to whatever the internal circuits need.
The pedal spec does say it needs a 300mA supply, so there may be a power-up demand a bit higher than 150mA, but it will be brief and I would expect even the old 200mA version to work. If the rating is 300mA or higher it will be fine.
https://www.musicalstore2005.com/strumenti_accessori/Seymour-Duncan-Andromeda-Dynamic-Digital-Delay.pdf
The 8V supply may not work even if the current capacity is high enough, a lot of newer digital pedals have sensing circuitry and won't power up if the supply isn't adequate.
I also have this in my spares draw , will it do the job?
https://ibb.co/6RSCz1S
