Fender Player Road Worn HSS Stratocaster and a parts/project guitar
Fender *edit - Player (not Vintera)* Road Worn Stratocaster - Candy Apple RedTexas specials and Pearly Gates Plus pickups.
Fantastic guitar, excellent range of sounds, great condition (always seems odd saying this with an aged guitar but you get what I mean)
Includes Fender gig bag.
£760
SOLD: Fender USA Performer Telecaster in Blonde.
It has one finish crack on the upper side of the lower bout - must have had a dink. Other than this it is in outstanding condition throughout.
Comes with Fender gig bag.
Located in Swindon or.
FURTHER EDITED TO ADD:
Parts/Project 'Explorer' (please read carefully)
This is a self-build guitar I did years ago in one of the forum self-build challenges.
It is an Explorer shape but 15/16ths size in overall dimensions, and also slightly thinner than a regular Explorer (I mention the thickness so as to be clear you can't add a term (should you want to) as the block would be too deep :-) )
It's mahogany (I think) with a spalted maple top. I bought the body blank unfinished - I stabilised the salt using the (apparently standard) method of rubbing in a large pot of thin cyanoacrylate (superglue) and letting it sink in, then sanding back a smidge.
I then finished the whole think using the 2-part clear finish they use for pub bar tops. Th finish is, ahem, imperfect, and has over the years begun to flake in some areas. To be clear, I expect you'd want to refinish or touch up yourself obviously.
The bridge is a hipshot (I think, from memory).
The neck was from a 'Jaxville' cheapo guitar. I used a rattle can to spray the headstock black. Again over the years, this has... let's say reliced!
I had a DiMarzio Super Distortion in it and it sounded EPIC. The guitar is really light, really resonant, and when I used it at the IGF summer school jam sessions (I ran the jam stage there for a few years) people always uassumed (from a few feet away) it was some booteek thing because it sounded huge.
What's it worth to someone for a project? £50?
Red ones are better.
I’m just never destined to be a Tele person I think.
