Strange Logic Audio Problem. No sound on audio track til I load software instrument !!!
I’m just getting back into using Logic again. Have forgot everything
  Seem to have got everything working . Could not get any sound from the Audio Track with my guitar
  The green Track meter was bouncing up & down but could hear nothing.
I then thought for some random reason ,what if I load a software instrument track
did so , then opened up the little keyboard input thing on the screen and used the mouse to hit a few notes . Switch back to Audio track it’s. Now working as one would expect .
im totally baffled
here’s some of my settings & my interface
  • hollywoodroxhollywoodrox Frets: 4210
    Ps everything works fine when I’m using a standalone plugin instead of Logic so assume the interface is all correct etc . Is it just a strange anomaly I have the IQ of a backward ape & still feel ill from Xmas virus . Is it anything to do with the audio input output screen above ? Wasn’t sure what ascending meant
  • octatonicoctatonic Frets: 33837
    Why don't you have the scarlett set as both input and output device?
    edited January 16
    My monitors on this are plugged into the headphone socket of the laptop I’ve only got 2 USB slots
      I can unplug the focusrite and use the midi controller or other stuff while still having a reliable output .
  • HabaneroHabanero Frets: 254
    When you add a new Audio track it normally doesn’t activate Input Monitoring, the switch for which is in the Inspector panel. Was this on?
    I’ll have a look later on , thanks very much :)
    Get a USB hub.
    You usually get much worse latency if using the onboard output.
    Get a USB hub.
    Thanks for that  I was looking at a hub but some things appear to not like working with them
    Get a USB hub.
    If a powered hub from a reliable brand then it shouldn't be too much of a problem.
    I have about 40 things connected to rackmount USB hubs in the studio.
  • marxskimarxski Frets: 251
    im totally baffled
    This problem got me baffled as well - this helpful and quick tutorial solved it for me in seconds.
    https://youtu.be/K6Sz7JJyP74?feature=shared
    im totally baffled
    Thanks man , I’ll check it out later  , have a great day
