Things you learn after quite a few years .. add yours
  • HAL9000HAL9000 Frets: 11237
    It’s ok to repeat phrases.
    It’s ok to leave spaces.
    It's better to play a few notes well, than to play lots of notes badly.
    Don’t even look at it! Don’t touch it! Don’t point even...ok, you’ve seen enough of that one.
  • SupportactSupportact Frets: 2286
    Playing live is different to playing at home. But also playing in the studio is different to both. You need to be able to adjust.
    Breathing really affects how our minds and bodies work. If you can control your breathing you can control things like nerves or adrenaline.
    You can't ever complete becoming a musician so you might as well work with what you've got now rather than wait to be good enough.
    Listening is the most important thing for making music.
  • BarneyBarney Frets: 662
    Practice on one string all the way up the...then practice on 2 strings ...work on intervals and phrasing .....do the same on all string sets and positions and using different scales
  • edited January 2024
    Stage fright is for pussies. You are not going to die and ninety percent of the people watching only wish they could do something like you are doing. So just go for it.
    My youtube music channel is here My youtube aviation channel is here
  • topdog91topdog91 Frets: 1499
    Ugh.
  • TanninTannin Frets: 6744
    ^ This. (And do as I say, not as I do.)
  • BillDLBillDL Frets: 14853
    If I pick up an electric guitar to play and realise that I don't have a pick to hand, I no longer feel compelled to go and find one as I can play, albeit slightly differently, without one now.  It only took me about 35 years to finally realise this even though my default with an acoustic is with my fingers.
  • TeyeplayerTeyeplayer Frets: 3934
    edited January 2024
    Less is more, the only folks who care about the number of notes you can play per-second are that knob from the blues jam who needs to learn to turn his amp down and the spotty kid at the back who can’t even play. The rest are here to hear the song, so serve the song not your ego.
    Lower output pickups are warmer and more articulate than a high output pickup and are preferable in 99% of cases.
    Know how to jump and mix between using a pick and fingerpicking, it’s got more dynamics than a board full of fancy fx.
  • blobbblobb Frets: 3960
    Drinking before a gig is NOT a good idea.
    Feelin' Reelin' & Squeelin'
  • Danny1969Danny1969 Frets: 12918
    I think that's an age / experience thing. I rarely do a gig completely sober, if you are used to drinking and playing it's not an issue and a few beers makes a more pleasant experience.
    If you aren't used to drinking and playing though then yes it's not a good idea, although a pint might help someone of they are really nervous. The trick is not to over do it.
  • stickyfiddlestickyfiddle Frets: 34681
    I'm with Danny. It's about knowing what works for you and what doesn't. Getting bladdered (or even tipsy tbh) is obviously a bad move, but like any good pub pool player knows you probably perform better after 1 drink and not a drop more.
    Yeah, know your doses!
    That said I was in a band once where we had to impose a pre gig 2 pint limit as at least one of us tended to lose all motor skills after that point. In general though people just have to know their level.
    I haven't played a full gig for a while now, I also haven't drunk alcohol for a while either. I suspect if the two were to be combined, it would be catastrophic!
    When I was doing the Kate Bush tribute band I had no more than 2 beers or so before the gig and only one in the interval break. That music just demanded a lot of concentration as it was a lot of borrowed chords, key changes, extra bars here and there and other things that could throw you.
    I'm pretty sure I have played Brightside, SOF, Dekota, Valerie etc more times than the bands who wrote the songs so it really isn't something that demands a great deal of sobriety really.
    I would be hard-pushed to play through 2 songs without needing a piss desperately after only one pint of beer these days.
    1reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • distresseddistressed Frets: 777
    edited January 2024
    I think body adjusts after some time. My drummer is sort of functioning alcoholic, like 10 beers a day. But he takes a piss no more often than us.
  • LewyLewy Frets: 5278
    Counter point: used judicially, some flash can really enhance the audience's perception of what they are receiving as a piece of entertainment. People respond to ability too. If you decide that the ability to play fast is just for people who overdo it, you're placing an artificial constraint on yourself. Also, the discipline and practice it takes to be able to do it will benefit every other part of your playing.
  • darthed1981darthed1981 Frets: 18028
    You will actually be much more successful with women if you are trying to sleep with them, than if you are after a relationship... and actually more likely to end up in a relationship as a result.
    Oh... you mean GUITAR things...?
    edited January 2024
    I agree with ‘used judiciously’ which is why I think you’ve missed the nuance of ‘serve the song’. If it requires something flashy then it’s absolutely beneficial to be there and a little flair in small doses, can win a crowd over. But when it’s all over the song and purely about ‘look at me’, then an interesting audience response was the one given by a non-musician friend whilst watching a local player recently: ‘he is actually just masturbating’.
  • BahHumbugBahHumbug Frets: 376
    If you’re intending to make music with others…………
    1.  The ability to communicate properly about the music will save a lot of time and will win you a load more kudos from other musicians than your blues wailing.
    2.  It’s not all about you.  Leave space for the other instruments.  Listen and learn to spot where two instruments are fighting for the same frequency band, turning both into mush.  Then do something about it that doesn’t involve turning up the volume.
    0reaction image LOL 1reaction image Wow! 5reaction image Wisdom
