Nifty little trick for your pedals maybe?
PetepassionPetepassion Frets: 872
On a snug pedalboard I'm sometimes knocking the pots on a pedal when switching on another. Just cut up a piece of coolant hose, taped together then glued.
Doesn't mark your pedal and easy to lift off for adjustment if needed.
Not sure if someone has come up with this exact idea? But it's cheap and easy to do.
‘It is no measure of good health to be well adjusted to a profoundly sick society’
0reaction image LOL 4reaction image Wow! 1reaction image Wisdom
  • stickyfiddlestickyfiddle Frets: 27182
    Another I spotted on the Jason Isbell rig rundown is grolsch washer under the knobs. Just makes them a little firmer to turn I guess
  • PetepassionPetepassion Frets: 872
    Ah, yeah I like that. I have trays of washers in my workshop, copper, ali, rubber, might give it a go.
  • merlinmerlin Frets: 6720
    edited January 22
    I have washers under the knobs on my 3leaf audio Wonderlove deluxe... Makes them tight and stops nightmare scenarios.
  • shuikitshuikit Frets: 224
    edited January 22
    I've seen people do this with a (wide) rubber band, never tried it myself though
  • chromatunachromatuna Frets: 373
    edited January 22
    I have been using black rubber washers from the plumbers’ merchant down the road for a long time, does the trick for me, doesn’t immobilise the controls but they are much more tended to stay put. I think I confused the guy at the counter though trying to explain what I wanted them for :-)
    p.s. that green Amp 11 looks very tasty
    This is the truth from hillbilly guitars!
  • english_bobenglish_bob Frets: 5163
    Between straplocks and er... pedal knob stiffeners, a guitar player could get through a lot of Grolsch.
    This reminds me actually, Ive been meaning to get one of these for my RD because it's actually quite easy to knock the volume controls when setting up on stage in a hurry & in the dark
    https://www.etsy.com/listing/615697744/stormguard-pedal-knob-guard-origin
    ^^^^ very neat
  • BrioBrio Frets: 1874
    It's the £10 postage that puts me off. Nice though.
    OK, just come up with a simpler method and works a treat...
    0reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • ElectricXIIElectricXII Frets: 1144
    @Petepassion That's nifty. What size (OD) hose are you using?
  • OK, just come up with a simpler method and works a treat...
    Potentially useful for onstage snacks as well.
    Blackbird Cabs - bespoke guitar cabinets, handcrafted in North Devon
    sam@blackbirdcabs.com
    28.5mm OD. I'm using silicone hose as it's a bit softer, so grips better
    A peculiar diet sir :)
    Rubber sump bung washers with small, thin ali washers underneath to centralise on BOR and Timmy
