Qotsa - I think I lost my headache guitar sound
SpaceaceukSpaceaceuk Frets: 18
Tapping to the hive mind wealth of knowledge on here . Queens of the Stone Age have a song called I think I lost my headache . At 2:04 the guitar comes in with the most wonderful tone . Do you think this is purely amp overdrive or is there some pedals involved in this one . Someone on a Reddit mentioned a JHS twin twelve could get you close but I’m not so sure. Any thoughts?
  • robertyroberty Frets: 10911
    Wow yeah that is a cool sound
    No idea how it's made but it sounds to me like there's a pedal and an overdriven amp involved, and some clever EQ
  • Moe_ZambeekMoe_Zambeek Frets: 3431
    edited January 26
    Possibly one example of the alleged peavey decade sound? Which is available in pedal form via a few companies, notably the Acorn Amps Solid state preamp pedal.
  • CirrusCirrus Frets: 8495
    It's two takes, sounds like they're hard panned. I'm at work just now so I can't mute a speaker to hear each one in isolation. but they both sound like small amps, and the magic is in the contrast between the two tones and how they interact. The left one is quite dark and woofy in the low mids, quite a vowely tone. The right one is brighter and tighter more standard.
    Just listening without being familiar with the gear they'd use (I know they've used loads of different stuff over the years), It's hard to work out what the signal chains might have been. Plus mic choice and position has so much influence on the frequency balance too.
    I've been using a 1x10 IR on my Captor X quite a lot. It's a really good trick for contrast
  • TeleMasterTeleMaster Frets: 10355
    Great track! You have good taste. :)
  • dangriffithsdangriffiths Frets: 575
    edited January 26
    Afaik Peavey's came on the next album Songs for the Deaf so was more likely Ampeg V4/VT40 but he has always tried to keep some secrecy about his sound (as he says its taken him years to work out). Cocked wah and EQ pedals for sure used at points too. Not sure there was a lot of pedals until later and all boards are about with images online.  Fulltone Ultimate Octave for later stuff is great. The Catalinbread SFT I liked too
    Good info for Songs for the Deaf era in this video (which was originally deleted from the guys channel but then reposted):
  • Winny_PoohWinny_Pooh Frets: 7831
    There was a long video by Eric Valentine. From what I recall multiple amps, multi miked, Ampeg combos and eq pedals heavily mid boosted.
  • Sounds like an Octave Fuzz is on there. Also, the correct tuning will help. There's a reddit thread discussing the same song here: https://www.reddit.com/r/qotsa/comments/aq9nsv/advice_for_an_i_think_i_lost_my_headache_guitar/
  • ReverendReverend Frets: 5045
    The video is interesting. The peavey Decade was the key o the bass sound.
    On the guitar he went back to the Tubeworks that was the main amp in the 90s. Blended with the peavey head he strangely says are weird/crappy but are exactly the heads youd associate with that drumming.
  • Homme is also known for using drop C standard tuning and pretty heavy strings. If he's done so on this track then that will contribute to the sound a little bit.
    It really is mostly down to the tuning (and his predilection for cheap, solid state gear).
  • StuartMac290StuartMac290 Frets: 1475
    I know they record his guitar through a pair of cabs facing each other with a figure 8 mic. They move the mic back and forward along the axis between the amps to adjust the phase relationship and change tone pretty dramatically. I think that's where the cocked wah thing comes from, amongst other things.
  • KurtisKurtis Frets: 751
    Someone actually made an album called songs for the deaf?!
    they were doing that live a lot as well.  when homme and Olivera played in Master of Reality they were using Sunn Model Ts set up like that.
    I don';t think its thing for cheap gear for him. It's very much the gear his hero's used. late 70s peavey mark 4a crop up in photos and live videos of the likes of Black Flag ( the album is defined by black flag drum fills) Minor Threat, Bad Brains at so on.
  • EricTheWearyEricTheWeary Frets: 16303
    Although I prefer Dan Baird’s Love Songs for the Hearing Impaired which is more both more fun and more politically correct.
    The Homme in a box pedal is the Stone Deaf PDF or PDF 2. Josh used one although I’m not sure how much.
  • guitargeek62guitargeek62 Frets: 4199
    So did Troy.
    The Skeleton Key is a pretty good pedal for their tones too, but almost has to be running into an on-the-edge-of-breakup amp for best results.
  • TravisthedogTravisthedog Frets: 1848
    Stone deaf FX PDF1 or 2 and muff will get you pretty close to most JHs sound for the first few albums at least especially that tone you speak of in ITILMH - that’s the PDF1 for sure
    Sd1 is worth a go. Think he used them back then
    Doesn't this album pre-date the PDF1 though?? The album came out in 2000, and I remember the PDF launching - I didn't start playing until 2006, so it must have been after that.
