It’s still not as good as if you put it in a 5E3-sized pine/tweed cabinet with a Jensen alnico speaker, but it’s a lot closer.
Since then, there rest of the market has really stepped up the game in this category of amp, whereas fender really haven’t IMO. Especially for £600 new.
Can think of at least a dozen amps in that bracket I'd rather have.
A bit like the Orange Tiny Terror. The first in its genre but at this point far from the best.
But I’m really clueless about valve amps
what would be the ‘better alternatives’ in this class/genre that have been alluded to? Genuine question
I've got a Roland Blues Cube Artist and an HRD IV for gigs. I have a preference for the clean sound of my HRD, but the Blues Cube Artist clean isn't far behind and it certainly sounds a lot nicer than my HRD when things get crunchy. The Blues Cube is also quite a bit lighter. Both work well with pedals.
On that basis I might also consider consider a Blues Cube Hot.
My Blues Cube Artist can certainly keep up with a loud drummer on the 45W setting. I've never needed to go to the 80W setting. So I'm wondering whether the 30W Blues Cube Hot might be loud enough to gig with, and possibly have more clean headroom than a Fender Blues Junior IV.
I have master full whack by default which makes a difference. Fat button is shite, reverb not great and can be over powering.
But sparkle/glassiness on mine is really nice esp with humbuckers. LPC and SB59 sound superb through it. On strats does edge type stuff really well. Tele twangs like it should.
Heres a comparison of 3 vs 4 stock.
I ran it with the master full up and the gain low. Clean.
I need to try both.
Did you see the Andertons video where Lee Anderton picked a Blues Cube over other amps in a blindfold test?
