Amp issue: Ever increasing Bias on 2 EL34 valves only
Ok, this amp issue is beating my local amp tech, and he's one of the best.
The bias on one pair of the 4 EL34 power tubes slowly increases. The amp is a nicholls from the late 60s / early 70s. 100 watts with four inputs. Similar to my old (and sold) Sound City 100 watt Mk3.
I will get a full explanation and the failed solutions soon. And there's me thinking it was down to the fuse blowing every so often (imagine my embarrassment when I left the amp with the tech saying there's something wrong with the amp and he saw that two valves were blown white).
In the meantime, I'll post some gutshots to give you all an idea.
  • lukedlblukedlb Frets: 488
  • ICBMICBM Frets: 72610
    Probably the coupling cap from the phase inverter on that side leaking. I would replace both of them.
  • RiftAmpsRiftAmps Frets: 3180
    My first thought too, but you'd have to assume that the tech is competent enough to have checked that already, no?
    @lukedlb when you say the bias is increasing, do you mean that the -ve voltage on pin 5 is climbing towards zero, or that the current running through the valve is mysteriously increasing whilst the bias supply remains stable?
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    I would have thought so too, but I think it’s the most likely explanation. If it does it even with new valves it’s not one faulty one in the pair pulling down both of them either… not many other options if the other side is remaining stable.
    (Or not unless it’s a DSL/TSL100, which was my first thought :).)
    Yes, tech has tried that. And these:
    Replaced grid resistors
    Replaced capacitors
    Bias circuit redone
    Reversed the inputs
    Inverted output transformer
    Replaced the valve sockets...and many other tests and various measures
    I don’t know the answer to that, sorry.
    Which pair is it that runs away - the ones nearest the PT, or nearest the preamp valves?
  • jca74jca74 Frets: 355
    Love the 7.5 ohm/15 ohm outputs...
    It’s the valves near the preamp
    The current running through the valve is increasing. The tension on the bias on that pin is slightly lowering, even if all the components around the valve have been replaced.
    The amp tech is the most experienced I know and the only person my friends and I trust with vintage amps. But this issue is perplexing even him so I wonder if any of the amp techs have ever faced a similar issue.
    edited February 29
    Not on such a simple vintage amp as far as I can remember.
    If he hasn't done it already - although I assume he has, if he's experienced - I would disconnect the PI coupling caps at the power valve end first and make absolutely certain it's definitely a power stage problem. If that fixes it, and they've already been replaced, try reconnecting them but disconnecting the NFB loop.
