Clean back of neck (satin/open pore) ?
TimmyOTimmyO Frets: 7541
What’s a safe way to clean finger-poo from the back of a neck that appears to be very open pored?
Red ones are better.
  • bertiebertie Frets: 13569
    if its anything like your strings used to be,   an angle grinder.
    TBH, Ive never cleaned any of mine  -  they dont get "residue" dirty,  but a couple could do with a "spruce up"      I know a couple of companies do, do specialist  "satin finish"  cleaners
  • TimmyOTimmyO Frets: 7541
    It’s not grim or anything - just feels like it could do with a light clean - I’ll just use a micro fibre cloth unless anyone has a neat suggestion
  • TheMadMickTheMadMick Frets: 245
    When you've rubbed it down, put a little talc on your hand and rub it up and down the back of the next. Note: a LITTLE or it gets messy. That lubricates the neck until your skin fat takes over.
    Do not polish the back of a neck - makes it sticky.
    edited February 23
    defo this.
    this is me "thinking"  not advising,  considering a satin/oil finish neck is the same as a fretboard........... you'd "think" that  a board cleaner would be OK - but Ive seen no reference (good or bad) anywhere
  • thermionicthermionic Frets: 9671
    Taylor make a cleaner for satin finishes which might be worth considering.
    Nice one - thanks
  • Try some green or white scotchpad but go gently at first.
  • BigPaulieBigPaulie Frets: 1114
    Definitely DON'T try green Scotch pad?
    It's way too coarse and will eat right through a satin finish to bare wood in no time.
    Yeah I’m not using scotch pad
  • KittyfriskKittyfrisk Frets: 18936
    Have you considered using the ultra fine (almost completely non abrasive) melamine cleaning foam blocks?
    Usually marketed as magic eraser cleaning block or similar.
    They really are quite amazingly useful but can wear out very quickly. Thankfully they're very cheap if you shop around.
  • KurtisKurtis Frets: 732
    Warm damp cloth.
    I always find that fragrance free baby wipes are a safe way to clean most things.
    If it's safe enough to clean a baby with, it's probably safe enough for your guitar.
    True but people have been wiping babies with warm damp cloths for a long time before.
    Better for the environment.
    edited February 25
    thing is,  there's normal gunk,  and Timmyo gunk............. the M&S of the gunk world
    some of the posts on Acoustic forum  recommend the white (non stick) pad to be used lightly
  • droflufdrofluf Frets: 3741
    Don’t baby wipes have some sort of moisturiser in them?
  • BillDLBillDL Frets: 7377
    The ones with no fragrance are generally just "water wipes", in which case just use a cloth dampened with warm water.
    edited February 25
    Thanks. As my “baby” is now 19* I’m probably a little out of touch
    *and would probably throttle me if I came within a mile of him with a pack of babywipes.
    For the uninitiated, Bertie is basing this on something that was more true 15+ years ago - I have quite acidic sweat, I can kill a regular set of strings in a few hours if it’s warm/if I don’t wipe down afterwards. Because if that I ended up changing strings LESS frequently - to get the benefit of fresh strings I’d have to change every day or two and screw that.
    So I used to just get used to duller strings and change them when intonation got bad enough to notice.
    on a fateful day some forumites a gathered and I had a high end Avalon (during the period there were no Lowdens, so basically a Lowden)  that I’d let go, let’s say, a BIT too long lol . The gathered throng were horrified :-)
    These days my body chemistry seems less corrosive, and I play less, so it’s much less of a thing.
    The issue at hand here is simply the fact that I *think* I can feel a bit of left hand skin residue on the neck, and given the open/thin/satin finish I thought safest to ask.
    I’m intrigued by the melamine foam idea - has anyone done it?
    Apart from me I didn't know, so had to search for a 'citation'  ;)
    https://forum.ukuleleunderground.com/threads/“restoring”-satin-finish-using-mr-clean-magic-eraser.155297/
    To be fair, there will be more environmentally friendly ways to do it, but I use it so infrequently that it hardly counts as a major polluter. It is generally re-useable, before it eventually crumbles.
    Just wet the foam/sponge lightly with water & gently massage the surface, checking for any debris build up like you would with any abrasive.
    If you have deeper pores in the wood, then possibly a soft toothbrush & maybe white vinegar would do it without affecting the finish?
