https://www.thefretboard.co.uk/discussion/260839/digitech-screamin-blues-ditto-looper-spark-mini-mxr-berzerker-marshall#latest
Right off the bat I'd recommend the Nux Loop Core. But if that's too complicated for you then the Mooer Groove Loop or Micro Loop.
I've got an RC3, but I haven't used it in years, as I bought a Digitech Trio+, however when I did use it I found it, I did find the hold/tap thing a bit of struggle unless I was using it regularly. I should really have bought/made an expansion pedal for it, but I bought the Trio+ instead.
One button for record or overdub. One button for stop/clear. And a knob for loop level.
Job done.
You can use a switch to change the function of the stop button to trigger reverse or half speed, but I don't.
