Apologies if this is a strange request... I've just ordered an SC20H amp and am wondering what cab to get for it. I've heard mixed reviews about the accompanying cab from Marshall and think I'm pretty settled on v30s. But before ordering a heavy and expensive item, I'd like to play the amp through them to confirm it's what I'm after.
So to that end, does anyone here have a 1x12 or 2x12 cab with Celestion v30s that they'd be kind enough to let me put my amp into to hear it? (To be clear, I'm not asking to take them away or borrow them)
It’s probably just as easy to go to Anderson’s and try a bunch in one sitting. They sell the SC20h so you won’t even have to bring your own.
You’ll probably feel more comfortable there than in a strangers home!
I had that head. I mainly used it with some Eminence cones that were in a Jet City cab. Sounded great. Not as fizzy as V30.
It's also great with Greenbacks and the under rated G12-65. Not many stock cabs with the latter though.
OP - what sort of music do you play?
Good to know the 1x12 also sounds bigger. Do you think there would be any issues with sound being too focused in one direction in a live situation?
The SC20H is still really loud. I still used an attenuator at home even in 5W mode. The power section needs turning up a bit to get the bass working properly. Sounds a bit thin otherwise.
https://www.ebay.co.uk/itm/305430800094?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=NIyqMH5uRyW&sssrc=4429486&ssuid=&var=&widget_ver=artemis&media=COPY
