Anybody any good at decrypting passwords?
m_cm_c Frets: 1244
As per title.
I've agreed to sell a 3D printer that has a RPi at it's core, however I've forgotten the password that I set, and it's not the default RPi password.
However I do have the encrypted key from the FTP I used to connect to it, but my skills are failing at successfully decrypting it.
I have the code used to encrypt/decrypt the passwords, however my attempts at running it through a decrypter have so far failed.
I suspect the issue is the FTP code is adding Hex conversions, which the online decrypters can't handle.
Plus all the code is in C++, which I'm fairly hopeless at.
If there's anybody who wants to give this a go, I can supply all the information.
Worst case scenario, the RPi OS needs reinstalled fresh.
  • fretmeisterfretmeister Frets: 24466
    What’s your mum’s maiden name? Pet name? Credit card number? CVV code? Street you lived on as a child?
  • maharg101maharg101 Frets: 700
    edited March 12
    Reinstall the software from scratch on the RPi ?
    The FTP user probably doesn't have shell access, and could be FTPS (secure FTP), or SFTP (FTP-over-ssh). The latter has more chance of shell access, but probably doesn't have it, and almost certainly not privileged access in any case
    If you don't have the original installation media, can you download it or otherwise get a copy from the manufacturer?
    This one goes to eleven
    Trading feedback here
  • munckeemunckee Frets: 12413
    edited March 12
    The password is "IvorBigun" and your pin is 6841 for both your debit and credit cards strangely. You are wearing blue.
    When you say you have the encryption key, what do you actually have ? Feel free to DM me on here.
  • snowblindsnowblind Frets: 292
    On the off-chance the thing is running openssh to service sftp requests you might be able to get a shell using an ssh client and the file transfer creds. All depends on how loosely it was set up. There's always crackers like john the ripper if you have a way in but the overhead of running it would mean it is probably easier to to reload the Pi.
    Alternatively, settle down in a nice, comfy chair, a large glass of something refreshing and picture yourself setting it up. Chances are the password will float to the surface of your mind.
    Old, overweight and badly maintained. Unlike my amps which are just old and overweight.
  • thermionicthermionic Frets: 9669
    This is exactly why you should write your passwords down in a little notebook bought specifically for the purpose, and keep it at hand in somewhere easily accessible and obvious, like on your computer desk.
  • m_cm_c Frets: 1244
    Reinstalling the RPi OS/Software is fairly straightforward, but it would mean losing the current settings.
    AFAIK FTP access is using the main/root user details, as I couldn't be bothered setting up a separate user just for FTP, especially since the files that got modified over FTP are in the main user directory.
  • ShrewsShrews Frets: 3034
    It will be some variation of a password you use for other things, but just with a special characteristic that the password requires
    Example: Me1234, could be Me1234! (if it requires a special character). It could be one that will not allow 'weak passwords' so you may have entered Me1Me2Me3Me4!! instead.
    Best way to tell is to try re-entering a password and see if they give you guidance on what they expect from a strong password.
    But I bet it's a variation of one you've used before.
    Full details.
    I know the user name is 'pi'.
    The FTP client I used was the NppFTP plugin for Notepad++
    The hashed password stored is '1BCB6351F77B25D10A'
    And the defaultKey used by NppFTP for encryption is 'NppFTP00'
    NppFTP is apparently using openssl DES 64bit Cipher Feedback.
    The source code for NppFTP is on Github - GitHub - ashkulz/NppFTP: Plugin for Notepad++ allowing FTP, FTPS, FTPES and SFTP communications
    And the encryption code is - NppFTP/src/Encryption.cpp at master · ashkulz/NppFTP · GitHub
    Which also makes use of Hex conversion in StringUtil.cpp
    Somebody has made a decrypter script, but I don't have any easy way of running it - notepad++ nppftp decryption routine · GitHub
    So you have the SSH private key for the main/root user. If it has a passphrase on the private key, presumably you know that, since you were using it for SFTP. So there's nothing to decrypt.. just use the private key to ssh into the pi.
    It won't be a strong password, however it's not the password I've used on my other printers.
    For anybody to hack the printer, they'd have to first get through my firewall, then hope the printer was actually turned on.
    See my newer post.
    The FTP plugin stores the actual password as a hash, and then decrypts it internally before connecting over SFTP.
  • guitartangoguitartango Frets: 1028
    Can you not take out the sd card and pop it into a computer running Linux?
    Edit the /etc/passwd file
    pi:x:890:pi:/pi:/bin/bash
    remove the x
    pi::890:pi:/pi:/bin/bash
    save it, insert into pi and login with no password
    “Ken sent me.”
  • wolsnahwolsnah Frets: 190
    edited March 13
    @m_c From the info you've provided, password looks to be just rp3Dprint
    0reaction image LOL 2reaction image Wow! 2reaction image Wisdom
    Thank you!
    I knew it would have been something simple.
