I'd not, did the purchaser use the correct PSU?
These things are fairly robust.
Or, was he aware that you have to plug a guitar cable into the input to power it up?
This too - although it would still work on batteries.
INPUT
Power on
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
Sometimes when you are trying gear out there may be cables and adapters all over the floor. I've seen loads of pedals fried in this manner
Two things will harm it .., the wrong polarity and too higher a voltage
The worst thing that could be connected is a PSU with a linear AC output of 17 V or so .. typically used with black star valve pedals, Alto mixing desks, some rack processors.
I'm not an electronics genius but any stretch, but if its not coming on at all I'd imagine something is toasted inside, unless the input jack has got buggered.
ive had 2 of these units & never had any problems they’re pretty bomb proof
