https://www.amazon.co.uk/Brother-HL-L2375DW-Wireless-Connected-Printing/dp/B0784DKXYY/ref=asc_df_B0784DKXYY/?tag=googshopuk-21&linkCode=df0&hvadid=311024248734&hvpos=&hvnetw=g&hvrand=2255650765376904085&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9045997&hvtargid=pla-420077770762&mcid=df9ee1df9c6c33c4bc4ba58a3fbd2d8e&th=1
Sometimes I print double sided so it does involve having to refeed the paper tray, first two times I did it I didn't turn it the right way, I think I have to turn the side I just printed upside down and put in there, I got it right on the 3rd time I think.
But overall quite impressed. There's a funny smell coming from it though....
Any initial smell should disappear soon, but it might well be prudent to check that you removed all the thin adhesive plastic tape that is used in assembling the printer. It is usually blue & is everywhere
And yep all the sticky tape has been removed, at least I hope anyway!
Offset "(Emp) - a little heavy on the hyperbole."
On a separate note, I plan to sell the b/w and colour inkjet cartridges for my old deceased printer, as I’d keep stocked up on supplies, but seeing I don’t need them anymore I might as well sell. The colour one must be about a year old as it been lying around unused. Will it be alright to sell? Or will the time have dried up the ink? The b/w one is only a few weeks old so that will be fine.
Most modern printers go into suspension/sleep/standby mode after a while to save energy, so leaving it on won't use very much power. Switching it off & on daily shouldn't cause issues, but if possible I'd be inclined to try & save up print jobs & then print them in one session. You would then only need to switch the printer on every few days or maybe once a week.
No right or wrong answers, just try to figure out what works best for yourself.
Yeah I only switch it on when I actually need to print anything, which is max 1 time per day so its not like I'm switching it on/off 3-4 times in the same day. Just don't want to wear out anything quicker or use more ink than I have to.
The trick is to get used to your printer's normal startup & running sounds, then be alert to anything that isn't normal.
Here is a reasonable guide to how they work https://computer.howstuffworks.com/laser-printer.htm
