I'm seriously looking at going down the digital modelling route and reducing my number of amps, partly for the flexibility of being able to get more sounds out of a single unit, and partly because with small children sleeping when I've the time to actually play guitar I end up using headphones through an old line6 pod most of the time.
I'd need something that would sound good going straight into the desk in a live situation, so presumably need cab and mic modelling, but also need it to work at home with headphones.
Ideally I'd like to spend under £800, but would be willing to go used
(moved)
Oh, and for what it's worth, it sounds like you want a Helix LT.
This post will be replied to by people claiming Kemper or Fractal or Helix or Neural DEFINITELY sound better than the others.
They are all right and all wrong. And they'll ignore the Boss stuff even though Nita Strauss, Dave Murray, Nuno all sound amazing with them.
I have a Helix and love it. I am sure I'd be happy with many of the others. Maybe not a Fractal as I hate fan noise so much it makes me want to kill kittens.
Try a few out. Do not underestimate the UI. Making cool sounds should never be a hassle.
I've a TC nova system which I use as a stand-in when I can't be bothered bringing my main pedalboard, but it's basically used as "set and forget"; I've maybe 6 main preset setups on it which I almost never adjust at all.
I've discounted the Boss GT1000 on the UI, Kemper is too expensive and the screen on the stage version seems very basic and hard to read compared to rivals.
The Neural DSP Quad Cortex looks incredibly impressive, but is definitely overkill for me and nearly double my ideal budget.
Is there much to choose between the Helix LT or the Headrush?
The Core has all the vocal processing which I don't need, the prime is a bit over budget, and the Gigboard doesn't have an expression pedal (though is cheap enough that I could buy one and still be comfortably within budget).
I'll amend the thread title to something more relevant..
The price was too good to say no to, though after a very expensive month involving a custom shop fender and an 8 string I'll need to have a bit of a clearout
Jason Sadites has some excellent vids on youtube if you get stuck, or just ask on here.
Line 6 has a "Customtone" website where people upload their patches. Whether they are good or such depends a lot on what is being used to hear them, but there's some good layout options.
But before all that - make sure the firmware is up to date.
There are lots of menus, though signal chain and effects adjustment is very intuitive, even on device.
My only question so far is whether it's possible to assign one of the footswitches to switch between 2 amp models? (As this would effectively let me run a clean and drive channel without having to duplicate blocks of effects etc)
