Tele bridge saddles won't budge.
My saddles are stuck. Won't screw in or out. What's the best solution for this? I've removed the height adjustment screws and tried gripping the barrels with pliers, but they are stuck...
  • GSPBASSESGSPBASSES Frets: 2351
    They look a bit rusty, so possibly good old WD-40 might solve the problem.
  • paulnb57paulnb57 Frets: 3073
    edited March 24
    Heat might loosen them, try holding the tip of a soldering iron at the join between saddle and screw, until each get hot then try unscrewing, do one at a time and try unscrewing while still hot, stick a bit of cardboard under the height adjusters to insulate from the baseplate,  perhaps a squirt of WD or similar the night before
    Worst case Dremel (or similar) the screw heads off, stick  the screw shafts in a vice and soak in WD and heat with something a bit more aggressive, then replace the screws
    Even worse case Dremel the heads off and replace the complete saddles
  • FunkfingersFunkfingers Frets: 14573
    My smile is stuck.
    I cannot go back t'yer Frownland.
  • KurtisKurtis Frets: 742
    edited March 24
    Some penetrating oil might help.
    You could grip the screw (below the head in case you damage the thread) with some needle nose pliers and twist the saddle rather than chewing it up with a screwdriver.
  • lovestrat74lovestrat74 Frets: 2533
     I tried the WD40 treatment before. Think I might try the heat method. Then if not get some penetrating oil
  • SteveRobinsonSteveRobinson Frets: 7079
    In some cases the combination of the two often works.
  • CountryDaveCountryDave Frets: 859
    Had a similar situation a while ago.
    Pushed the screws back through the rear of the bridge and Dremel cutting blade did the hard work.
    New set of compensated saddles fitted.
    Same here Dave
    Rusty barrels 1
    @lovestrat74 0
  • ICBMICBM Frets: 72638
    Cut the screw heads off and remove them from the bridge, grip the screw shaft tightly in a bench vice, and wind the saddle off.
    Nah. They are the "threaded" steel type. Bin 'em!
  • BillDLBillDL Frets: 7391
    The last time I had seized up parts on a bridge I mixed up about 25% engine oil (5W-30 synthetic, not that I think it matters) with about 75% white spirit, poured it into a glass jar, and allowed the whole bridge to sit in it for a couple of days. It worked well, but I had no basis for comparison other than the fact that WD-40 hadn't worked.  I think the difference simply was that it's impossible to submerse components in WD-40 without spraying out a jar full, and soaking the parts with it and leaving it in a ziploc bag isn't really submersion.
    Well, you could, and replace them with the plain steel ones which are actually the best :).
    I’m not totally convinced the threaded ones don’t sound slightly better though… I know it’s odd, or maybe just very subtle, but I think it may be that the threaded ones seem to be a very hard steel.
    Bruce had plain steel ones on the Born To Run guitar though, so they are by definition the best.
