Dear all
I have been here for a few years and 300+ posts.
Love this community and support, and I would now appreciate a bit more.
Like some other enthusiasts, I have been on the roller coaster of pedal purchasing, Helix, Kemper, mini board, heavy amp, Tonemaster etc.
My current Helix purchase five months ago has not brought joy as I have come to the conclusion yet again
, that I don’t like digital computer based amps/updates, fiddling, patch downloading etc.
Unlike my favourite YouTuber John Cordy!
So, unused Helix (switched on four times and Screen plastics still on!) and Powercab will be up for sale shortly.
I love Vox tones especially, but also Fender cleans.
My gear swapping is not enjoyable and annoying me intensely.
Any advise re. Purchasing valve amp that’s not too heavy. Vox AC15 was!!
Home player and some stuff at church.
blah —— guitar wise I have sorted this swapping, but amps and effects em seem harder to master.
This is a symptom of my own mental health, but I need to find a solution.
ta all - jon
My recommendation is figure out what family of "amp" and "effects" you like the most from the Helix and then find the best real versions of those.
Sound advice. I really want to buy a 1990 Vox AC30 (UK Kory era) which is for sale locally.
Dream amp, but so heavy and I can’t imagine moving it!!!
AC4 more sensible but that AC30 sound!
ICBM has said more than once that the AC10 is closer to the AC30 sound than the AC15, and it would be lighter too.
You'll get more answers sticking into the main AMPS bit. You can move it yourself by using the little Cog Wheel icon on your first post.
Jon
https://docs.google.com/document/d/1Ei7OMETiM_U1mSroXqbGwrKtxy19oWcRzhOCqXdO8Xg/edit?usp=sharing
Seriously, give one a go before spending £££! The Nu-tube tech feels nice and valvey.
One option is get a lightweight cab with a Celestion Neo or similar and then a head like an AC15 or something if you like Vox.
Other than that you might be better off with a tonemaster (although I see you've tried that), or a Bluescube.
At home it's too easy to get sucked down the rabbit hole of tweaking endless settings rather than just playing, but once you get the helix set up it's also very handy having the portability and knowing that you've got 3 or 4 good sounds right there without needing to worry about mic position etc, and also just having the guitar and helix to bring rather than guitar, pedalboard and amp.
In a band mix I find you don't notice the difference from a "real" amp
That's why I just bought a helix having previously used a Nova System to leave my pedals at home, I'm now leaving the amp at home too
It is 20w but it gets great tones at low volume, has a great FX loop.
Pricey though.
Don't rule out something a bit further off the beaten track either, there are some good amps which cover both types of sound quite well while not being either a Vox or a Fender, and contrary to popular belief the valve type is not the important factor. Something like an Egnater Tweaker will do both, although you have to use very different settings.
The Mesa Blue Angel might work, although despite having both 4-EL84 and 2-6V6 power sections it doesn’t sound especially like a Vox or a Fender - and it weighs a ton, unless you can find the head version and get a lightweight cabinet.
it has both 6v6 and EL 84 output tubes so you can essentially switch between Vox and Fender. It’s not a direct copy of either amp circuit but after owning one I can tell you it will definitely do a very convincing impression of black panel, tweed abd AC type. Really impressive little amp!
only sold mine as it didn’t have reverb or an fx loop to add verb..
only real downside is the combo is HEAVY! And quite hard to find in the uk
