Rattly bloody valves
  • jca74jca74 Frets: 355
    ICBM said:
    If they made a version with dummy valves round the back I think it would fool a lot of people. And rattle as well :).
    Don't remember the company but someone did this in the 90s. Fake valves with leds in for the glow....
  • impmannimpmann Frets: 12678
    Yup, Carlton Amps iirc
  • ICBMICBM Frets: 72614
    They weren’t fake, they were actual solid-state valve replacements. If I remember rightly they had reliability issues and never made it past the development phase.
    The company then tried making valve amps, which sounded absolutely awful - ironically, they’d previously made all-solid-state amps which sounded very good.
  • LittlejonnyLittlejonny Frets: 140
    Yes JJs are shite in my opinion. I always used to have rattle problems with them, and they really don’t sound good.
    I eventually discovered Harma from Watford Valves and EHX can be nice as well. They really do sound better too - it’s not just snake oil.
  • GavRichListGavRichList Frets: 7200
    Never heard of harma but I’ll have a look. The way my brain works now means that I have a staunch brand loyalty to the red plate / premium selected TAD offerings, *just* because they’re a vast improvement over the JJs. I’m special like that.
  • BoromedicBoromedic Frets: 4883
    edited April 15
    Shame Harma valves are a house brand for Watford Valves which means I'd never buy them, plus they are just rebranded valves from somewhere. The snake oil people mention with Harma isn't their standard valves, it's the ridiculous cryo horseshit, plus the owners attitude.
    EHX are okay but spiky sounding, not as smooth as others generally. JJs can be good, just not as reliable or long lasting sometimes. Internet searches indicate Harma valves are from the same factory as EHX which is Russian origin (new sensor) I believe.
    My head said brake, but my heart cried never.
  • springheadspringhead Frets: 1602
    If you buy ‘direct’ , JJ or New Sensor/Reflektor then you are doing QC checks on their behalf. I think they give them a cursory performance test but nothing more. Harma and TAD are buying valves from those two factories and putting them through their own performance, noise, microphony and burn in tests and rejecting x% of them.
  • Modulus_AmpsModulus_Amps Frets: 2595
    JJ 6L6 and 6V6's often suffer from rattles, Sometimes there is even bits of mica loose in the valve that you can see and hear when you rattle the valve.
    The main reason internet wisdom suggests JJ 6V6's is they are meant to handle higher voltages better, like those found in a deluxe reverb.
    My experience in swapping out vintage (RCA??) 6V6's with JJ is that I preferred the vintage ones, so if you found modern ones you like and they don't fail on short notice then that's perfect.
  • Alex2678Alex2678 Frets: 1155
    edited April 16
    I was on the fence about trying something else having installed JJs after a shorted Groove Tubes 6v6 last year and this thread tipped me over the edge, bought some tad red base 6v6GTs. Glad I did, sound great and an irritating high pitched ringing that I was blaming on the reverb tank has now gone. The JJs can sit as spares but as long as I can get hold of an alternative I think I will
    This pleases me greatly
    I see there is now a more durable version of the JJ 6V6 with double top mica spacers, wonder why they thought to do that.
    A custom version of the JJ 6V6-S with a double top mica for increased stability. The double mica improves support for the tube structure and reduces mechanical vibrations in its components. These double mica 6V6 tubes are a great option for combo amps and any amplifiers exposed to speaker vibrations.
