My LP type currently has 10s in E standard but I might try a 9-46 and see if that works.
Mind you sometimes I like to tune the LP to D or drop C and that's not going to work. 10-52 would probably be spot on for that.
It gets very expensive to experiment with strings!
When I started playing 35+ years ago I used 9-42, but then went up to Ernie hybrids at 9-46. I put them on everything too.
Not as much choice back then though!
Light bass strings have a lot more top end and heavy are more thumpy at the low end, but lose a lot of top end detail.
I always went as heavy as I could stand because I assumed thick strings = better, but it makes you think.
I was 11s on everything, but I go 10s on Strats 11s on PRS and Gibson now and I might go thinner now I don't play as much.
My head said brake, but my heart cried never.
https://www.youtube.com/channel/UCg_imQDC4eUOjuBBRl2mBwA
https://www.youtube.com/watch?v=LyQgllCIpqY
https://rozaliftwave.bandcamp.com/
I’ll add that I appreciate my comment may come across as absolute. I’ll clarify a bit.
but my preference is 10-52, I love the tuning stability (when you did in) for recording , I’ve also noticed better tuning when used with a capo … I have no idea how much it has on sound, it’s all about the feel for me
I'll persevere with the 9s if only because I bought a 3 pack
I still use 11s on acoustic - I really don’t hear the big tone difference between 11s and 12s, especially as two of the strings (A and D) are exactly the same gauge usually, but I’ve started using 10s on electric. Just a little easier to play and no significant tone difference. I borrowed an Ibanez RG for a while recently and had 9s on that because that’s what the owner used, it was absolutely fine. If I buy one I’ll probably do the same, although I might get a custom gauge set (9/12/15 - 11 is too light for the B and 16 slightly too heavy for the G in a standard set).
With acoustic strings the G in a set of 11s is the bad one - most sets use a 22, which is crazy as it’s a 23 in a set of 10s!
