There is a vintage Laney 4x12, essentially the Iommi cab, which also sounds great.
Otherwise, there are similar cabs in a number of the packs, such as a 4x12 with Greenbacks, and they all sound quite different even with the same mics in the same position.
I'll be using it with a Tone King Imperial 2.
I'm going to try it with the Blonde 63 2x12 Cab and a Dynamic 57 Mic, I'll add a little reverb and EQ to suit at the venue.
Will let you know how I get on.
I went with the Friedman 4x12 with dynamic 57 rather than the blonde 2x12 as it sat better in the mix, I don't think it's the cab sim I'm going to stick with, but as a straight out the box cab sim, worked well.
