Poopot's Cover Challenge #27 - the letter N
  • flying_pieflying_pie Frets: 1825
    @thecolourbox in the playlist
  • stickyfiddlestickyfiddle Frets: 27396
    I’m getting there. Vocals still to do, and I have an idea I want to try as well but not sure if it’ll work.
    Far more going on than in the last one but sounding ok so far I think
    IMG_3736.jpeg 130.1K
  • SporkySporky Frets: 28893
    So... just to check again, if your cover doesn't actually sound like the original, but your best beloved says "Is that meant to be No More Heroes?" on hearing it for the first time, it's OK?
    Because if The Stranglers had made video game music this is totally what "No! MORE HEROES!" would have sounded like.
  • thecolourboxthecolourbox Frets: 9932
    I'm glad you clarified with your second paragraph there, because I was going to say that entirely depends on whether you meant it to be a cover of that song, or a cover of Backstreet's No Diggity, for example.
    soundcloud.com/thecolourbox-1
    edited April 22
    I'd taken my first attempt at a cover of No More Heroes, and turned it into (I thought) something else, but apparently despite having a completely different chord sequence and no singing, it's recognisably derived from it. Sort of the main keyboard line but with a few notes changed.
    Also there's a shred keyboard solo, so I suppose that's in keeping.
  • TTonyTTony Frets: 27792
    Your dinosaur talks now???
    edited April 23
    Only to me.
    I have reconsidered, and will submit it in the next composition challenge instead.
  • idiotwindidiotwind Frets: 483
    I've sent in another entry.  It was finished a while ago, but I've been messing about with the mix, the amount of reverb on the vocals, all that sort of thing.  I also went back and re-recorded the main acoustic, but as I hadn't particularly stuck to a click I then had to take time to get all the other parts to line up.
    Anyway, the song is Nine Times Blue by Michael Nesmith.   I kept things quite simple, acoustic, a couple of tele parts, organ and electric piano.  I also worked quite hard on the vocal, particularly the harmony part.
    @idiotwind in the playlist again
    I've sent in a silly entry I'm afraid.  Dutch techno played on a Les Paul.
    And I've added a track of my own which happens to be the same bloody silly entry as idiotwind except mine is Dutch techno in the style of RATM
  • HabaneroHabanero Frets: 255
    Sent one in.
    @Habanero in the playlist
    I have done zero since 2 weeks ago. Partly because I have far more ideas than I have time.
    Bear with me...
  • fnptfnpt Frets: 750
    I would like to submit an entry on behalf of a Brazilian friend. not the right letter so I hope that’s ok:
    https://www.instagram.com/reel/C6hlOzZp5zq/?igsh=NWU1aW9vM2ttbXQ0
    ____
    "You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
    I've sent in my entry.
    ____
    @fnpt in the playlist
  • monquixotemonquixote Frets: 17716
    I've tried and given up on a crack at No More Heroes, but I've got another idea I've put an hour or so into so far so I'm hoping to have something for this one.
    The last one I entered was "E" so you could say I'm not very productive  =)
    In time honoured undiagnosed-likely-ADHD fashion, have about 16 viable ideas, and a handful of them with parts on virtual tape but life has got in the way. Maybe I’ll finish one this week but tonight I have a project management training course for 3 hours after work which is really exciting, I can tell you…
    Wish me luck!
    Wish me luck!
    Good luck, but there's still nearly a month left.
