Precision Bass Pickup Recommendations
  • stickyfiddlestickyfiddle Frets: 27397
    GoFish said:
    Anyone tried the Lindy Fralin?
    Not P but I had a set in a J for a bit and they were really nice sounding pickups. I just don't like Js enough to keep it.
  • SchnozzSchnozz Frets: 1996
    By the demos, the Lindy sounds defined like the SPB-1 but meatier. Front runner for me at the moment.
  • OssyrocksOssyrocks Frets: 1675
    I have a Fender Custom Shop pickup in my MIJ 62 RI. I like it a lot, and it compares very well with the pickups in my 70's basses.
    However, I would be tempted to go to Ash @OilCityPickups for one in future. Ash rewound a vintage '73 Jazz pickup for me last year, when it spontaneously died. He did a splendid job, with exact replacement wire etc, and I must admit it sounds rather better than it did before.
    Rob
  • OilCityPickupsOilCityPickups Frets: 10855
    Rob
    Thank you Rob :-)
    Could anyone help me with the dimensions of their P-Bass pickup cover?
    I have 56mm in length and 27mm in width, but the screw holes in the 'ears' are 66mm apart... It looks like the screw holes are normally less than that.
    If the length and width are standard, I guess I could just put those covers on, but then I'd need to check the poles and spacing.
    Looks like its normally 61mm as opposed to the 66mm mine has...
    UPDATE: I think I'm fine, as a 55mm x 25mm bobbin can fit inside, but I just need to find out who does those...
    Seymour Duncan are 54.4mm x 25.4mm. Talkbass states a common 53.5mm x 24.8mm replacement, but they don't mention the maker.
