I've not driven the petrol one have to admit, obviously no BEV lacks for punt.
What I do is clean the hub with a wire brush, clean the inside of the wheel , make sure both mating surfaces are very clean and flat, apply a small film of copper grease to both, it stops the corrosion that binds the wheel to the hub.
Feedback
AFAIK most people aren't aware that getting super-low profile tyres is a bad idea, unless you do track days every week:
You get a rougher ride, and more chance of a fractured wheel on a pothole or kerb, or tyre damage.
I opted for the least-low-profile setup when I bought my car
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Also, make sure the car is in gear as well as with the handbrake on, that will lock all four wheels and remove the chance of it rocking forward/backward off the jack as the brace tries to turn the wheel - and mean that it's also easier to tighten the nuts with the wheel in the air since it won't try to rotate.
(I'm one of those old-school people who always put the car in gear when parked anyway, so I don't have to remember that...)
