EL84 valves
FatfingersFatfingers Frets: 500
Does anyone know what these are? It claims they're military valves but doesn't mention any manufacturer.
  • ICBMICBM Frets: 72677
    They look like bog standard Sovteks to me. They have the typical 'funnel' getter holder and the plate structure looks the same.
    They may well be 'new old stock' as in being not made very recently, but they're still modern-production valves so the 'NOS' is a bit misleading. The Soviet military certainly used them, so that's not likely to be wrong.
  • ESchapESchap Frets: 1428
    Pretty certainly the old Sovtek "black plates".  These have a strong following over on AX84, where funnily enough there is much discussion about all thing EL84 and the amps you might build to put them in.
  • Thanks. I need a pair for the Ampmaker P1800 kit I've just taken delivery of.
