experiencing intermittent loss of volume and distortion, lasts a few minutes then comes back on. Have tried complete set of known working valves, no difference.
I believe its the power stage of the amp as when I take a line out(send) and plug that into a bandit its as clear as a bell. sounds like a problem I had with another amp that turned out to be dirty in and out jacks but I have sprayed and cleaned these. any guidance please
I'm sure the Cub's were susceptible to problems with some kind of thermal switch. I don't know the technical in's and out's but if you google "Laney Cub thermal switch" it should throw up some pointers.
Sorry if it's a half-arsed answer but hope it helps.
I read about that but I think it made the amp cut out entirely, and mines the later one which came with the HH speaker.
I wonder if its dirty pots as sometimes when I mess around turning the knobs it comes back again but sometimes not so it may just be coincidense
It's bad design. If it's properly specc'ed, an amp should not need a thermal cut-out in the filament circuit.
It will be something in the power stage, but if it's not valves you still need to take it to a tech.
that's what I suspect. the preamp output is fine. but its all been ok for a couple of hours, light leave it on until bedtime (about 1 am) here periodically checking it. Hate the thought of taking it to a tech and them not finding anything wrong as its behaves itself waiting for mw to get it home.
is there a chance it might have been a scratchy pot that's worked itself clean or am I completely barking up the wrong tree?
